You said that you wanted to build a 4 door GT-R. Genuine, factory built, GT-R sedans are almost impossible to find.
My point is that doing it yourself by getting a 4 door chassis and transplanting the engine/driveline from a GT-R coupe into it is going to be a massive job with lots of custom work from whichever workshop you eventually get to help you with it. The end result is more prone to failure than a 4 door car that left the factory with an AWD drivetrain, and OEM levels of engineering and testing behind it.
If you're talking about just dropping an RB26DETT into a sedan chassis then it should be relatively simple, and reliability will come down more to how you treat the car than anything else. But, to be quite blunt, the GT-R is defined more by its advanced drivetrain than its engine so that car wouldn't be a "4 door GT-R" any more than some ricer who sticks badges on their GTS-t.
If you intend on having the GT-R's ATTESSA (which is different to the GTS4's ATTESSA) fitted as well as the engine into a sedan, which would make it more worthy of the title, then you're going to need deep pockets and people who really know what they're doing. Even then, I'd still be worried that things had to be kludged to fit/work, which means it's more likely to break than a car that was designed to be that way in the first place.
Check out these threads.
http://www.skylinesaustralia.com/forums/98...Gt-t297401.html
http://www.skylinesaustralia.com/forums/R3...ld-t280439.html
My opinion:
If you are going the R34 N/A route - Keep the 4 door as "daily spec" - With minimal mods. High flow panel filter, extractors and a decent sounding stereo (not the full DOOF DOOF stuff - adds so much weight and takes boot space) and some nice alloys. This will also enable you to get parts from the nissan dealerships.
R34 non-turbo are not quick cars (on par with your typical n/a aussie 6s), however they do keep pace with the "majority" of cars out there - so they are not underpowered by any means. I'd put them as VERY average. Only real advantage of the n/a R34 is the better handling and the good looks (majority of people out there have no clue between the bread and butter GT/GT-T to the GT-R).
When you save up enough you could probably end up having 2 cars :P R34 4 door as a daily and a GT-R for the weekend/having fun...
I just picked up a R32 sedan gtst with Rb26dett conversion
plenty of mods done to it, upgraded brakes, tein suspension, 750cc injectors, ecu, gtr fuel pump, etc
they are around, need to be quick tho when they pop up
about to strip it into a track biatch
unless you want it for 10k ;)
buy a POS first car cheap as chips
save as much money as you can in the mean time
when off p's buy an ER34 GTT and youll be fine
ER34 GTT to GTR conversion is stupid, pointless, not worth the $ and a waste of time
the money youll spend all up - you could just buy a GTR R34 for the price they are now
the converted ER34 GTT to GTR will be worth nothing in comparison to what you spend
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
