Hey all i poped a welch plug under the inlet manifold and im wondering if there is a way to change
these with out removing the inlet manifold its one closer to the front of the motor.
Also why would it be getting to hot i am running a large thermo fan new thermostat and 50mm alloy r
radiator and still gets hot ??
Thanks
Please help any guides or picks would be great
https://www.sau.com.au/forums/topic/302149-r32-rb20det-welch-plug-help/
i have just about finished doing this my car and let me tell you......never again if you want to do it right you will have to remove the intake manifold, also replace them with brass ones and use plenty of stag or take it to a mechanic because its migraine
Replace ALL the welsh plugs while you are about it. If one has failed, the rest can't be too far behind.
Your overheating problem is probably because you are running a thermo fan (that's my experience, anyway).
Because a thermo fan relies on on air moving through the radiator only when the car is moving. This isn't always guaranteed. Air can escape out under the car rather than pass through the radiator.
The factory fan is always working, and always draws air through the radiator.
Sorry to high Jack your thread but in my build the rb30det I'm missing the welsh plug under injector 1 problem is it ain't showing up as a part on the Nissan system . Do you know where I can hunt this ? It's 13. Mm in diameter
    • No need to drill any holes. There's plenty of access to reach through and behind all of that steel to "push" from behind with a pulling action on the slide hammer. There's all sorts of attachments you can screw on the end of them.
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
