I'm thinking of using slicks soon but realised I know nothing about them like size (will fit under our skylines), brand, do you have to use front runners and what size rim people are using
I heard you can use a Ford chaser rim which would be a very cheap option but am not to sure if this is true any info would be great and handy to all
Thanks Brett
https://www.sau.com.au/forums/topic/30218-slicks/
OBHAVE from melb has run a 9.8 using a rb25. From what i know he did a 10.3 with 430-50rwhp thats auto.
Manual is the creatd motorsports black one from melb which was a 11.16 @ 126mph.
Both cars i believe had gutted interior and full slicks on 15inch rims and front runners.
Also 16inch au rims do not fit. They hit the brake clappers though yes they are the same stud pattern. I tried this.
Buster, was your time on nitto's? or standard st tyres and what mph did you get.
https://www.sau.com.au/forums/topic/30218-slicks/#findComment-614818
I run nittos as standard street tyres every day of the week as they are only a semi slick radial tyre
At the end of the day no different then the Dunlop DO1J, Falken Azena, Bridgestone Re540 semi slicks that people use for street/track work ie a radial tyres though the nitto is better suited for drag due to the higher sidewall then the other semi slicks I've mentioned
I ran a best so far of 11.8 @ 123mph with a 60ft of 2.0, I have ran a 60ft of 1.8 at lower boost but haven't been able to get the launch right at the higher boost level yet
We're lucky enough to have the new drag strip opening soon which will mean we'll get a fully prepped strip which should help a bit as I do kick sideways a touch going into 3rd and 4th on the part of the strip which isn't treated
Back on track though do you know anything about slicks?
https://www.sau.com.au/forums/topic/30218-slicks/#findComment-614875
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
