Hi,
I'm looking at some mild performance mods for my 'line. Not planning on taking onto the track for any major racing time, except for the occasional hoon along WSID once it opens :D
Anyway I'm trying to achieve around 200-200rwkW, and looking at intercooler upgrades to help that along the way..
Just wondering if it's really necessary to shell out on one of those 600x270x?.. front mounts, or will I be able to scrape by with a stock intercooler (maybe a r34 GT-T one if necessary)?
Other options I was looking at was a not-as-big FMIC, like an VR4 / Evo / Apexi (500x?x?) ones..
Any advice?
Cheers..
https://www.sau.com.au/forums/topic/30220-r33-gtst-intercooler-upgrade-qu/
Its impossible to reach that power level on the stock turbo on a r33 most of them seem to max out around the 180-190kw (I have seen over 200rwkw but on a dyno that reads notoriously high) so you will need to upgrade the turbo and the intercooler. Do a search on here for turbo's and you'll pull up a heap of threads one guy in particular has made good power using a vg30 turbo and modifying it slightly and ended up costing less than $500 I think. If you want a complete turbo I'd get something along the lines of a garrett gt25/40 (around $1900-$2000) and that will get you just over 200kw, if you want 250kw get a gt30 as for the intercooler just find a good locally made unit, you can get a good japanese kit like a hks or a trust from a certain person in japan but you risk paying import duty and gst (a total of 25% more).
the standard intercooler can be improved upon. My reccomendation is the trust tube and fin bolt in replacement. Around $900 and will support 200rwkw.
There has been a few R33's to get 200rwkw on the factory turbo, some with the times to back it up too. For street use and the occasional drag strip visit a front mount can be put off till you do some better value for money mods. I know of one gtst in perth with both factory ic and turbo to pull 211rwkw on a dyno that reads fairly btw.
hehe woops..maybe somewhere in the 180-220 range..I know that's fairly broad, I guess I'll see how I go.. haven't really done anything yet, just pipe dreams at the moment..
My car managed 200rwkw on 15psi with a stock intercooler...but it had alot of help from a high-flowed t04 compressor housing with a stainless steel wheel. then it needed an S-AFC, boost controller, pod filter, and a turbo back exhaust. The turbine housing is still stock.
The whole Hi-flowed thing was done by the previous owner...but yea, if not for that then i would probably be fighting alot harder and sleeping less trying to get money for mods that stretch the stock turbo to its limits.
With a FMIC, I can achieve 200rwkw at 12psi. It helps cos it's safer, and a cos of a retuned S-AFC
My point is that it can be done on a stock cooler, but nobody would recommend it. Things will get too hot. They could only run my car up to 200rwkw once that day cos of the heat soaking into everything.
Hi rev210.
Where can you get these trust coolers from, this sounds quite interesting..
Make sure you choose a FMIC suited towards the power figures that you are after. No point getting a massssive FMIC if you only want 180-220rwkw (which IMO is possible with the standard Turbo).
I managed 200 rwkw on the stock turbo (but like everyone says, the dyno could be reading a little high). I also have a VR4 cooler with larger inlet / outlets on the end tanks (as the originals were only 2" I think). Other mods are pneumatic boost controller (as seen on autospeed.com), K&N hi-flow panel filter element, 3" turbo back exhaust, and SAFC with A/F ratio's at 12:1.
When I added the boost controller and ran car at higher boost I felt a small power difference
When I dropped a hi-flow filter element I felt the car was struggling less at hi rpm. (I had a pod filter on before that, which felt NO different to a hi-flow panel filter, so only get a pod if u like the noise it makes..... I hate it though, so I got rid of it)
When I put the cat back exhaust on I felt almost no difference
When I put dump/front pipe I felt a little difference
When I put intercooler on I felt NO difference
When SAFC was tuned, I felt a HUGE difference.
I'd say don't expect too much out of your mods until you sort your a/f ratios out though.... With all my mods (minus SAFC) I managed a top of 164rwkw. My A/F ratio's were all over the place, and car ran like CRAP after 5000rpm. tuning my A/F ratio's helped me get the most out of all my mods, so make sure that (or aftermarket tuneable ECU if u can afford it) is on your list....
Thought I'd post my experiences up since your goal is same/similar to what I set out to achieve. Hope you find the info useful!
Zahos
Guest RedLineGTR
  rev210 said:
the trust intercooler is availible from takakaira.co.jp / greenline and nengun.
The side mounting of the intercooler has the advantage of much better airflow than the front mounting except the space is a little restricted.
side mounting the intercooler would u mean like getting a original mount cooler simialr to the stock r33 gtst one but bigger and fatter and that flows better??
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
