A few weeks ago my S2 Stag developed a very slight misfire at idle. Previous to this, it has always been super smooth (have to look at tacho to see it's running).
The misfire gradually got worse and is now quite noticeable at idle and when accelerating from idle to about 2800rpm, it is a constant stutter/misfire. 0-100km/h takes about 12-13 seconds. Engine-wise, the car is stock besides the coil packs mentioned below and a drop-in replacement K+N filter.
I have tried all of the following (after researching about 50 similar threads):
- Replaced Coil packs with Super Sparks
- Replaced Spark Plugs with BCP6ES @ 0.8mm and 1.1mm
- Check base ignition timing. 15 deg @ 650rpm, using a pluglead directly into Cyl 1 and also checked with timing loop wire
- Unplugged the coil packs one-by-one while engine is running and all are firing (revs dropped and idled even worse when they were D/C)
- Cleaned AAC Valve and AFM
- Unplugged/wiggled around all connectors
- Checked ECU for codes (No errors)
- Checked voltage drop from battery to all of the earth points on the engine. All are 0.00 or 0.01
- Sprayed Start ya Bastard around every intake and vacuum line. Revs did not change
- Tested TPS. With Ignition ON, but car off, idle is 0.45v, WOT is 3.9v. With car running, idle is 0.41, WOT is 1.4v (Is this a possible cause?)
- Tested AFM. With Ignition ON, but car off, reading is 0.22v. With car running, it is 1.14v
What else could it be? Coolant Temperature Sensor? CAS? Injector problem?
It does not have a boost gauge. If I get one, will I be able to tell if it has vacuum leaks by its reading at idle?
The car uses Castrol Edge 5-30 fully synthetic, changed every 5000kms, the 02 sensor was changed 20,000kms ago. It has 145,000kms on the clock.
Spent most of the past 3 days on it, as well as testing random things since it started showing symptoms. :geek:
Thanks for any advice
Edited by revolt
Far out, my car (34 GTT) also has an rb25detneo and is beginning to get quite a noticable missfire, i am getting some new coilpacks next week as it still has factory ones in there.
I hope i dont have the same problem, the 1st thing i would have checked would have definately been the coilpacks but you said you have just done that.
Perhaps the fuel pump/filter could do with replacing??
Didn't think of the filter. Will give that a shot. :P The current one has only done about 15,000km tho. :geek:
Have you tried removing the air flow meter and washing it through inside with brake cleaner? Sometimes the hot wire gets contaminated ESPECIALLY if you have ever had an oil impregnated "performance" air filter in it. The other easy thing to try is either `scope the output of the O2 sensor to see if it's dead or lazy, or just fit a new one.
Yeah thats not really a lot, perhaps and hopefully you got a dodgy one and replacing it will fix it.
Best of luck.
Yeah, that is another possibility, because it reads 0.22v with the ign ON, but not running.. others have said around 0.5v is normal?
try swapping out the AFM? could be the dreaded dry solder joint.......which I'm informed you can repair
Have you checked all your VACUM hoses for no leaks?
Yep, I noticed on the Driver's side in between the engine and stub axle (on one of the 4wd doo-dads) there is what looks like a vacuum hose that comes up to near the oil filter.. the other end is not connected to anything, but I can't see where it should go? Is this just a breather line or something? The other thing is there is a single pin sensor on the oil filter housing that is not connected. My guess is it's for an optional oil pressure sensor..
Unplugged the AFM while running and the car idles better. When I rev it with the AFM off, it revs smoothly up to the limp home 2500rpm limit, where it misfires like crazy. Is that 2500rpm misfire normal with no AFM? If so, my guess is my AFM is rooted since it's a lot smoother with the AFM off.
EDIT: OH! Very important thing I just figured out. It only does it when it's warm. I always drive sedately til it's up to temp, so I didn't notice but today I decided to flog it and see what happens.. it was perfect for about 5-10 mins.
Edited by revolt
are you sure TPS at WOT is 1.4v when running and 3.9v at ON but engine not running?
this would make the car run like ass if it was true
double check this please
ECU adjust fuel according to water temp i think. Perhaps the sensor is faulty and it's still running on cold start settings which would be rich i suspect??? No idea if that would cause your drama though.
if the water temp sensor is dead the engine check light will be on
if its out of whack and working (ie giving a valid reading) the ecu will assume the water temp is, what the sensor says
so if the sensor is out of whack the ecu wont know any better but if the sensor is dead the ecu will turn on the engine check light
When i did my FMIC install i forgot to plug the AFM back, and managed to get about 300m down the road before it started spluttering and spitting. So i guess i kept the revs low untill then :) Sounds like you "may" have a dodgy AFM. See if you can borrow a friends that is known working?
Bah, double post. But with the engine off, it's 0.45 at idle and 3.99 at WOT
Perhaps thats your problem then.
Mine is 0.44 at idle with engine off and 3.90 at WOT
Engine running i have 0.41 at idle and 3.79 at around 6000 rpm.
Ah, awesome! (well, sort of.. still have to buy one, but at least it might be solved).
Will pull it off and inspect it. Thanks for your help everyone! I will try to visit the forums a bit more and help others. :)
yeah its wierd that when the engine is running it doesnt go anywhere near the normal values
that would make the car run like ass as the ECU has mapping and fuel enrichment etc based on TPS (and AFM, but TPS is also used)
so whilst your floor it, the ECU doesn't detect you are flooring it and thinks the engine is only under some minor levels of load even though AFM is probably showing normal full voltage
  • Like 1
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
