Hey! Need some help deciding what to do with my wheels, they need some freshning up!
They're 19"x9.5 and 19"x8.5 TSW Thruxton with grey spokes/polished lip.
The car has got Millenium Jade paint and rusty bolts airbrushed here and there, also the enginebay and trunk is Kandy Apple red :P
Heres how my thoughts go:
Matte black spokes/Gloss black lip
OR
Black spokes/Millenium Jade lip
I dont think its worth trying to implement the Kandy Red on the wheels cause enginebay and trunk wont show when i drive around, right :geek:
Car as it looks now:
Enginebay and trunk:
Example of how Matte black/Glossy black looks:
imho those wheels look cheap and tacky... you spent sooo much money on the paint and then went and destroyed all that work with cheap chinese shit...
as i said in a thread of yours a while back, go meisters with rusted spokes and polished lip :)
Polished lip with shadow chrome spokes, gotta keep the polished lip though.
imho jap wheels are over rated and most do not suit the style of jap cars, most people get them for one of two reasons, (A) light weight (B) brand name, most of the people on this forum would get them for B
Edited by W0rp3D
Jade lip, black spokes
as i said in a thread of yours a while back, go meisters with rusted spokes and polished lip :D
:D
what they all said.
and where did those rust marks come from?
pop-rivets that hold the body kit on I'm guessing
The car has got Millenium Jade paint and rusty bolts airbrushed here and there...
Edited by PM-R33
PM-R33> Thx :banana:
Heres a close-up of how the 'rusty' parts look while getting airbrushed:
The wheels where rather expensive, believe it or not, might be my bad there, so i'd prefer to keep them, although in a perfect world they would be 19" SSR Professor's or Work Meister's ;) Also getting my hands on a set of Professors or Meisters is hard when you sit in Sweden, any tips where to find them on auction, worldwide?
Heres two Photoshoped version to give a hint, im not longer all that sure about the black/black version :S:
Edited by brother_david
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
