Hey peeps,
After reading a bit about fuel consumption, I think my afm might need replacing - as I'm lucky to get 350 - 400kms from a tank and that's even when driving on freeways & in 5th gear. Does this sound right - would a new afm improve this?
I remember seeing someone on the forum selling brand new afm's for around $100 or $110. Does anyone know who that would have been - they seemed to have quite a few.
Thanks.....hope everyone had a great new years.
https://www.sau.com.au/forums/topic/302249-air-flow-meter-fuel-consumption/
I don't think it's your AFM that's making your car drink more petrol or that you're getting less millage.
You may need a tune which would involve your AFM but I don't think you need your AFM replaced per say. It could also be your engine, the way you drive or a few other things. For example, I tend to drive off boost more now and get much more millage from my car - obviously...however, a tune would be good...however, if you really want a new AFM, go for a Z32 (AFM from 300ZX's) as they're the best bolt on replacement but you'll need a tune for this.
Good luck.
AFM Can be cleaned, must be done when it is cold, I use CO Contact cleaner.
Check the Oxygen Sensor is functional, laptop with consult, multimetre, greddy informeter etc. a new one is ~$78 There are many threads on this.
When did you last change your plugs(and service the car?) I personally did it when I did my oxy sensor.
Also check tyre pres.
if your AFM is shagged the car will run like ass, lots of smoke, overfueling etc
if you are getting sub 350kms to a tank the AFM is fine
things to check
check and replace 02 sensors - they have a limited lifespan and only
they die after around 50,000kms ish and the part is about $100
the 02 sensor is solely responsible for getting good fuel economy. with a good setup you can have plently of power and 400km's to tank each time easily
if you were getting sub 300kms to a tank, then 02 sensor is toast
over 300kms to a tank is fine. stop loading the engine up and stop bringing it on boost, problem solved
if you dont believe me (or others who have said the same) give your car to your girlfriend or mum to drive for a week
i bet they get over 400kms to tank
also what do you classify as "to a tank" are you measuring the same way each time
do you run it empty? do you fill it up to the top? how many litres do you fit in when you "think" its empty
the gtst fuel gauge goes past E before you are empty and then the idiot light comes on
the difference between near E and past E is around 40kms (at least) of light cruise
the 02 sensor is usually the most common thing to be the cause of poor fuel economy
as most work shops / services wont ever check it etc and theres no idiot / warning light that comes on when its dead
so you wont know if the sensor is dead / lazy the car will just run like normal.
you can find a replacement 02 sensor to suit ECR33 from your local repco etc
the same sensor matches the ford falcon EL which is a generic 3 wire 02 sensor
be sure to note, you must cut the wires and fit it yourself, it doesnt come with a plug
Good luck.
What if he still has the factory ECU? How you going to 'tune' it?
things to check
OZA 395-E2 from memory is the plug in one to suit GTST Confirm when you buy it. Trade price is approx. $78.
there you go - get that part # then
is that just for the loom and plug ? or plug, loom and sensor?
cos my sensor when i brought it was $140 from repco, generic 02 sensor 3 wire to suit el falcon
plug, loom, sensor. I paid $78 at bursons.
think i might get mine looked at also, my stagea is luck to see 380km out of 65ltrs i think.
How is it on the freeway?
... theres no idiot / warning light that comes on when its dead so you wont know if the sensor is dead / lazy the car will just run like normal.
Jaycar make a little kit that will show what is happening at the O2 sensor. About $35, DIY.
The R33 tank is 65L, the empty light comes on when there's about 10-15L left :)
How did I know? When I had my R33, I always fill it up full then drive until the light comes on, then refill. And whatever I put in minus the tank size = what was left in the tank. :)
Ahhh thanks everyone. I think the O2 sensor is what I was thinking of....somehow got it mixed up with the afm.
I generally drive it off boost and do a lot of freeway driving. It drinks that much that even if I'm in a 70kmh zone I'll generally drive in 5th gear. I'll generally only fill it once the petrol light comes on. I rarely drive the car because it just costs too much...so hopefully changing the sensor will help fix this. I'm planning on a pfc in the next few months, so with any luck that will also help and produce a bit more power.
I think it was the O2 sensor someone was selling on here for around $78 - maybe a bosch one....but who knows - I stuffed up by remembering it as an afm, so the guy could have been selling a packet of chips for $300 the way my memory is going.
Go to bursons and get a bosch one to suit R33 GTST OZA 395-E2 $78
You will need a special tool to change it, it is approx. $22 or you can borrow one if you know someone with one. If you still have a standard dump pipe and plan on changing it yourself in future, might be worth buying the tool. Make sure it matches your socket.
I found dump/front/highflow cat helped economy on my stagea.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
