Hey guys,
i've been having this problem for a little while now and i was hopeful if anybody here could help me to pinpoint the problem?
Sometimes, when im driving along, the car will cut out and stall all together..
When i turn it back on it does this:
When i turn it back off, and on again, its fine ..
I was thinking maybe its a shoddy alarm installation?
I tried changing pods and cleaning the AFM.. could anybody help me out?
Car has a stock BOV, happens every so often and i dont know how to re-create the problem to show any mechanics! :bunny:
Edited by shaun123
https://www.sau.com.au/forums/topic/302271-stalling-problem/
mine starts idleing like that as the alarm imobilisers kick in.
i have one of those brant pin pad alarms. it has a highjack setting.
once i get in the car, start it, close the door and put my seat belt on its enabled. so once any door is opened and my seatbelt in un-buckled after 40 secs or so it starts beeping at me and then the car cuts out
can be a pain sometimes...took me ages to work out when i first got the car...even took it to an auto elec and he didnt know.
I'm going thru the same problem as we speak.
A few mates have told me it could be a range of different things including air flow meter, fuel pump, coil packs, spark plugs, dirty throttle body blah blah blah.
I have an R33 RB25DET - very low k's so i don't think its the coil packs, i changed oil, fuel filters etc, i've taken it to a few mechanics and coincidently it runs fine and there are no errors that come up. Today i changed the spark plugs and it made a huge diffrence, now i can actually drive it up the road before it cuts out and starts coughing and spluttering. The spark plugs were black and smelt like fuel so its running really rich. I'm gonna get a new airflow meter bolted on next week to see if that's the problem - i'll keep ya posted.
If anyone else can help that'd be great. Even just some direction on what to replace next or even some suggestions on who i can take it to to get fixed around the Wollongong area. I'll take it to Syd if i have too.
Good luck
Casey
My r32 stalls like that once or twice a month... I still haven't figured it out. No codes, it just dies. Some times it will start up and be fine, others I have to sit and wait 30-40 minutes before it will start again. Not sure if it's related, but I can't get the timing lower than +25 even with the cas all the way ccw.
New fuel pump, new fuel filter, cleaned injectors, new fuel pressure reg, new ignitor, new battery, new spark plugs, borrowed coils from another car, new ignition loom, new (used) cas, new (used) ECU, new battery leads, pulled some extra earth leads, tested alternator, cleaned every electric connector on the car, clean & resoldered afms, cleaned aac, compression tested, boost leak tested, tested almost every wire in the loom.
Nothing helps. I'm so frustrated with it that I'm going to sell it next month if I don't get fix it.
Sorry to rant in your thread! I hope you have better luck than me!
i would be looking firstly at the IAC and AAC valves. they control the idle IAC, as well as the idle when things like the aircon is turned on or the steering is turned and more load is put on the engine at idle (AAC). these valves often get dirtied or blocked by carbon and don't operate properly because they become sticky. this is why sometimes turning the car off, or even just giving it a rev can be enough to make it idle better as you are making the valve move even more which can be enough to temporarily sort the issue out.
i'm guessing that isn't your car in the video and you are just using it as an example of what the car runs like? if so then the above is what i would do. if it is your car (even though the video is from october 08 and plenty of people have said what the problem is in the comments) then i would plumb the bov back in to where it's supposed to recirculate to (between the AFM and turbo) and that will solve the issue.
  • 1 month later...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
