Up for sale is a pod enclosure to suit an r33. I actually purchased this enclosure off these forums thinking it would fit on my car but I think it requires a high mount turbo setup judging by the pictures. Enclosure is in great condition but no bolts are included. Im asking $70 for the enclosure.
https://www.sau.com.au/forums/topic/302349-r33-pod-enclosure/
what are you doing tomorrow i would love to check it out and more then likely purchase PM me asap and we can meet up
Hey mate my number is 0433373183 give us a call and if you wanted you could come over asap to check it out. It would have to be before 3. Or tomorrow would be ok
Hey man I've got a guy in S.A interested but if that falls through I'll get bak to you. I wasn't sure if u were still keen or not as I've had several people showing interest and saying they'll come around but never show. I'll let u know how it goes anyway
so im guessing it wont fit a standard series 2 r33?
Nah it won't. It requires a highmount setup similar to the one in the picture or if you could replace the afm to turbo pipe with another pipe with a slightly different angle as the afm won't line up with the hole on the enclosure.
  • 2 months later...
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
