How does it not fit your S13?
A31 strut towers are the same as S13 (formation the the top, distance from one tower to other)....the only difference is the A31 has less height clearance, so in all cases, A31 braces will fit S13, since most S13 braces fit the A31 depending on how high up they come.
Sure it's not for something else ?
The distance between the strut towers is fine and so is the clearance for the engine, the issue is the firewall is closer on the S13 and hence the BMC sits next to the strut tower, whereas in an A31 it's placed further back
Did you try putting the strut brace on the other way, so the bar would be on the other side of the struts?
Also, what is your location?
Yes, putting it the reverse way the bonnet doesn't close
I'm in the ACT
  • 3 weeks later...
As far as my own personal research has shown, cefiro front strut barce an sway bar are unique and will only fit cefiro.
For strut brace i use UltraRacing and for sway bar Selby.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
