Hey guys done a quick search and couldn't find what i was after.
Basically I'm deciding whether to mount my bosch 044 fuel pump in-tank and external with a surge tank for my rb25de+t. The main plan was to mount it in tank but after doing a little more research i am heading towards the direction of mounting it externally.
Basically what are your ideas on this?
As for mounting the fuel pump externally what do i use to push the fuel to the surge tank? Can i use a standard fuel pump or do i have to get a special lift pump?
And how do most people mount the surge tanks? Weld on a bracket and bolt them in?
Thanks in advance for any help
had external set up in my r33 gtst..
i used a factory gtr pump as a lift pump to the surge tank, and an external bosch pump from the surge tank.
i screwed the surge tank and pump in a bracket to a piece of aluminium, then screwed that to the floor of the boot. i also screwed an L shape bracket to the alumiunium to mount the relay for the pump.
the relay just wires in to the pump signal, so when the original pump is on, it switched the relay and the bosch one runs aswell.. i had it running straight battery voltage and had an inline fuse just in case.
its good insurance against leaning out, knowing that it can support 300kw, means it wouldnt be breaking a sweat at normal levels... its a quality part, that is brand new and reliable.
plus it makes a kick ass noise when its external.
Use an 040 if you want to run intank.
For an 044 use a low pressure lifter pump like a Carter gold and a small surge tank 2.5lt, you can mount it underneath the car so you don't get that horrible whine from your boot as well.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
