For sale are what were my track rims. As the title states they're 3 piece ssr evoloutions in stud pattern to suit a GTR 114.3 and 17x9 +18 offset
Two have Good condition Dunlop 265/40/17 Formula R semi slicks
Two have Poor condition Dunlop 255/40/17 Direzza 03G semi slicks
All rims have some gutter rash but are in overall good condition. One is missing a centre cap although i'm sure its around the shed somewhere but for the purpose of the sale consider it MIA at the moment and not included.
Chasing $1200, prefer to sell to Adelaide buyer as postage can be a pita.
Contact Robert - 0423128994
Cheers,
Rob
https://www.sau.com.au/forums/topic/302417-sa-3-piece-ssr-evoloution-17x9-18/
  • 1 month later...
Crap! You're in Adelaide, otherwise I wouldv'e snapped it up in heartbeat.
Any chance organising postage (at my cost of course) to 3199?
Cheers
Grant
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
