I am buying 4 new tyres and have 18' rims. Can someone tell me what is the biggest tyre I can go all round on a 33 gtr please.I have standard suspension.I am confused by some things the tyre places have told me about going bigger on the rear etc, despite me telline.
cheers
https://www.sau.com.au/forums/topic/302421-r-33-gtr-tyre-sizes/
cheers
yeah man whats the offset ????????????????????????????????????????????????
Offset has no bearing on the size of the tyres. Only thing to consider is the width of the rim. Once you know that, check the manufacturer's spec sheet to determine the optimum tyre size to fit.
sorry I thought I corrected my post, but it seems I have posted a whole new post again. The rims are 18x9 all round. The tyre shops I went to told me I could go bigger on the back 275 and smaller on the front 235 and apparently with those tyres they still have the sam rolling diameter, HOW I have no idea.
Cheers.
what the hell , offset is important if you want the tyres stretched or inside the guards depending on what you want , if you say stock offset at least it gives a clue as to what you can fit .
jesus, what an abortion of a thread...
what are the sizes and offsets of your rims...
offset is needed as if you have say an 18x9+0 you would need smaller tyres than say an 18x9+30
245's sit nicely on a 9" rim, but remember that 235's are much cheaper in all tyres as they are a MUCH more common size and are only 10mm less contact area
if your car isn't insanely modifyed then 235 all round is fine for traction
Never seen 235s on 9s but the 285s I have on my 9.5s fits perfectly with no stretching at all. However, I have another friend with 265s on 10s and they look a bit stretched. I was told 265s would be the perfect size for 9s though.
18x9.5 - 265's all round.
No idea why tyre shop would think you require a staggered fitment.
Wouldn't 235s be slightly stretched on a 9"?
btw, rolling diameter can still be the same with different width size.
Cheers.
Don't go staggered on a 4wd car. The altessa system is designed for the same front and back. for 9in rims between 235-265 is legal as said above. Up to you. 245's sit best I reckon.
Also with +20 9in rims on a 33 GTR they will fit fine. No need to take offset into account because they are a very safe offset.
imho 235 is better on a 9" as they are a fair whack cheaper and realistically there is fuck all traction loss between the two sizes.
having said this i do run 235 front and 245 rear but i'm on 9.5" anyway
Thanks for that Richo makes me glad of the decision I made, I forwarded that link to the guy at the tyre place, he found it interesting and was glad we didnt go staggered either, now he knows not to recommend it to anyone with GTR's
Got 245's put on all round, thanks for the help peeps, appreciate it. Now to the rotors and brakes to get replaced.
What a load of crock! You shouldn't be stretching tyres on rims. Tyres are designed, from a performance and SAFETY perspective, to suit a particular width rim, irrespective of the offset of the rim. The total wheel width & offset and tyre size package should be assembled with the optimum of performance and safety in mind. If a particular wheel / tyre combo won't fit under the guards, then something is wrong.
And legally (roadworthy-wise) the rim / tyre MUST fit inside the guard, ie no part of the rim / tyre can protrude beyond the line of the bodywork..
Oh my god , lol this thread is eratic , i just wanted to know roughly the offset and wheel fitment the topic starter wanted ! chill , NO STAGGERED FITMENT on GTR Edited by blingtr
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
