High compression pistons, larger bore, balanced bottom end, stiff valve springs, aftermarket ecu, higher rev limit (assuming it is still making power)
with an na, you have engine capacity, head + ancilliaries flow, and rpm as your basics.
So if you had a 3.1/3.2L spinning to 7000rpm......
(going to a larger bore may not be a good idea, i dont know, im not an rb30e na tuning and motor building expert. its a good idea but i dont know if it will hinder the engines ability to rev or something)
my rb30e is getting a bit sick....
how much did each of your mods cost, who did it, what exactly is the mod, where is peak power, whats the powerband like etc???
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615498
the cam is a SURECAM (btw surecam make all the cams for chiptorque, and for the rb30 hp1,hp2,hp3 it's the same cam)
headwork was also done by surecam. double springs, lifter boxes machined, port-n-polish.
104rwkw's on the chiptorque dyno, power comes on strong 2500-7000
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-615645
  • 3 weeks later...
without n2o or turbo!
Turbo is probably the best bang for buck though! can probably pick up the bits you need for under $1k, and run low boost (6psi or so) on standard n/a block without too many dramas.
or the twin cam head conversion also (may as well get a turbo head put on if you're doing that).
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-638082
  • 3 weeks later...
let us know how you ran at willowbank?? i heard something about a 15.2 or something worse then previously..
went to willowbank and only got one run in. there was a huge storm and the event was cancelled. heaps of wheel spin and ran a 15.3.
got it tuned at chiptorque, not a lot more power, a little more topend.
the single afm is the holdup, once i get enough $$$ i'll install a mircotech.
with this setup as is i should be able to run quicker than 14.8, but with the tt/b's i have lost some bottom end power so i'll need to change diff gears....maybe
next time i go out to the track i'll put on some 14's and run standard rear suspension, should help the traction probs.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-666976
not enough!!!
it was only 4rwkw's, the total cost of the tt/b's was $200 plus dyno tune. so about 400 all up!
i really need to piss off the standard airflow meter! i was thinking...hole in the bonnet, round air filter, bonnet scoop.
BTW......for those that dyno there car in 3rd gear, i made 108rwkw's in 4th and 128rwkw's in 3rd.....
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-667165
4rwkw?? that's bugger all! I've seen way bigger improvements with an XF throttle body conversion than a twin throttle setup. How was your torque? improvement? I noticed more torque with the a twin throttle setup then outright horsepower. but then again, I think the twin throttle setup is more wanker factor than anything. When you going out next?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-675743
Had my car dyno tuned (again) on the weekend. Told the operator to do a run in 3rd gear and another in 4th gear, made 1-3hp difference between the gears (less hp in 3rd). Don't know where you get an extra 20kw from changing a gear?!?
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-678908
i had it dyno'd at chip torque by Lachlan Riddel (the owner) so ring them and ask him.
Should take the car down there just for a couple of power runs and get a comparison. I was told it's more than likely the way the dyno has been calibrated.
Anyway, I've been told not to reveal my hp figure but I'll be honest with you, we did loose hp but we always knew we were going to with the mods we did.
https://www.sau.com.au/forums/topic/30243-rb30-mods/#findComment-683815
    • Been over 2 months since I have done anything on the S15 and had a day off today so got stuck into mounting the radiator and intercooler. I ended up using factory bottom mounts as bolted in and I did order some gktech top brackets but didn't work with the PWR radiator so made up some with aluminium flat bar. Spent way to long on them but pretty happy how they are. Next job was the intercooler. Used some more aluminium flat bar and did the bottom mounts first. Top was easy as just one long piece and 2 90 degree coming off rad support and welded them on. The bumper support required some notching to let the outlets sit where I want so will add some reinforcement later to strengthen it. I have also bought ecu and waiting for it to arrive. Went with a Link g4x Xtreme but will be adding a ptmotorsport expander to add a few extra inputs over CAN. Went through a few different configurations on pclink to get what I want to allow future expansion for sensors and gearbox upgrades. Ordered gktech rear arms but looking at the hardrace lower control arms to have some extra adjustment too will see how the alignment looks after first setup. Got 2 more weeks of work before shut down and will have almost 4 weeks to work on this so planning on hopefully firing up mid January.   Also bought a 2015 brz with a heap of good gear, did noosa hill climb a month back. Owned it for 3 days changed alignment and sent it. Finished the weekend 2nd in class and only .3 off the 180sx best time last year. MCA Red coilovers, gktech rear lca, bolt on lock kit and tie rods, whiteline toe arms, cusco 1.5way diff and 4.5 ratio, endless brake pads, headers, exhaust, perrin intake and e85 tune. Electronic steering adjustment, nankang crs with koya wheels 17x9 +35. Have bought rear traction arm and relocation kit, extended studs and v3 tie rod kit. Planning on also getting flex tune as lucky to get 300km a tank with e85 and short ratio. Car is a heap of fun to drive and super easy to work on. AC in the line up at Noosa was mint in 35degree weather.
    • I'm 22 years younger than you mark, and I'm operating in the exact same way! Ha ha ha
    • All clamps are oem    one question is , what is the bit at the top on high pressure pipe where it connectes to intake manifold and other side goes toward the engine( see item in red circle in diabram attached)   ? Seen some people stating that should be removed on boosted application and skyline is boosted from manufacture so little puzzled. Mine is around 23pwi (700 hpish)   also some state it could be the bonjo bolt crash washer so bought two washers
    • what do you mean dead platform? People buy older, out dated and less power cars on "Dead platforms" for over $65k all the time.
    • That is really nice! Very nice finish when you have an oven to do the crinkling nice and evenly!
