ERG 4 point harness $200
Rays blue duraluminium lightweight nuts -$130
R33 series 2 front and rear seats in great condition - $75
R33 rubber intake pipe - $50ono
R33 radiator and hoses $100ono
R33 S2 window switch and door trim $100ono
R33 stock sway bars $50 for the pair
Nissan air purifier $20
Panasonic navigation system $20
https://www.sau.com.au/forums/topic/302433-parts-clearout/
  • Replies 51
Rays wheel nuts sold
You still have stock exhaust (per title) or has it been sold?
I am looking for a stock R33 muffler
Still got the stock exhaust, although I'm not looking to seperate it. It also comes with a factory option Nismo muffler.
I'll add photos and a price for it soon
https://www.sau.com.au/forums/topic/302433-parts-clearout/#findComment-5046147
yo dezz is it stock catback??? will it fit a GTR 33??? needs to clear for EPA. pm me if it does fit and a price please
Yeah stock cat back, + the front and dump, minus the cat
No idea whether or not it'd fit a GTR though sorry..
https://www.sau.com.au/forums/topic/302433-parts-clearout/#findComment-5046754
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
