Need to get rid of my R32,
Features.. (in no particular order)
- R33 turbo [Running 7 pound due to the actuator, will come with boost T]
- Blitz tuned ECU
- Full 3" Dump back exhaust [ Car will come with Cat]
- 500hp Walbro fuel pump
- Shortshifted Manual
- Heavy duty clutch
- Front mount intercooler
- Clarion Speakers w/pioneer headunit
- Solid trans mount
- Nismo type S struts and Lowered springs [still quite high, will not draw any attention at all, yet has a firm ride]
- very (VERY!) clean interior
- alarm/imob + remote centeral locking
- Pod intake rather than air box
- 17" rims (8.5" front, 9" rear..i think. its about that)
- car has only got front and rear GTS bar, no skirts or anything so it looks quite stock (how i wanted it), however, i have a BN sports bodykit in the shed if you would rather..
Negative..
- A/c doesnt work as Compressor has seized, replace and it will work
- panel damage to the Rear left of the car, apparently the prev. owners mate reversed into it or something.
- has repaired damage to the front of the car, no idea what happened, but the car drives and brakes perfectly straight.
- front left quater panel is red but has been spray painted black. exterior isnt 100%, could do with a spray.
- solder joints in the AFM where the plug joins on have screwed out. all you need to do it take it out, open it up and blob some solder in there. one has cracked so the engine freakes out randomly (fails to detect the AFM so it wont rev over 2500)
car has done about 140XXXKm. everything is legit. ive done a rego & regency history check. car is currently regestered.
idealy i will sell this car sooner rather than later. i wont put a price up here, but if your interested, send me a PM of your offer. (i will run it in a "silent auction" sort of way.)
if someone offers me what i want. BAM its yours. (and its not too much.. lol)
will get pics in the next day/few days
- Rules say i need a price.. so... $7000 and its yours today. (whatever day it is you read this)
- ive got a buddy that wants this car for 7, but is getting a loan, no idea whats happening with it though. tempt me and its yours.
Edited by haleja
https://www.sau.com.au/forums/topic/302465-sa-1991-r32-gtst-black/
Got pics?
keen for swaps?
VT V6 Fac Manual 5spd, has had new Xtreme Heavy Duty clutch fitted 500 kays ago, new belt, tensioner, water pump, power steer pump, new engine mounts, inner and outer conrol arm bushes, adjustable castor rod bushes, Machanicals in A1 condition, alwayz serviced 5000 kays or less. VY SS 18s very good tyres, Pedders touring front and rear springs, Lukey extractors, cat back exhaust system one lukey muffler, FULL WH Statesman Tan Suede interior, PWR Windows, FULL Electric Drivers AND Pass Front seats, , Ice cold air, just regassed it.
8th pic down shows the panel damage, just needs to be pulled out.
and the front left quater panel will cost $220 from grand auto (a nissan wreckers down south). you can find cheaper parts no prob.
the AFM is the airflow meter. the pod filter bolts onto it (its a little box). just needs to be removed, take the top off, resolder 5 pins, then put it back together.
- the problem that it causes is that the ECU cant detect the airflow meter, so it goes into a safe running mode, in which it wont rev over 2500rpm.
when driving this causes the car to just "cut out" for a split second. then come back to life.
it skitzed out on new years, so i just jumpped out and pushed/wiggled the plug into the AFM so the join reconnects and ever since then it hasnt had an issue.
so, untill you fix it or replace it. the car MAY randomly loose power. which if it does, you can just shake the plug and it will fix it. (for an unspecified amount of time)
probably untill you go over a decent bump.
a new airflow meter will cost (I THINK) $150.
not a big issue.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
