Hey guys,
Curious to know what works in getting the front cam oil seals to do their job properly. I recently had my engine apart and upon putting it back together i reused the old cam oil seals as they looked to be in decent condition and didn't use any gasket goop around the edge as has been suggested by some, and now find I have a slow oil leak out the exhaust side..
I've just picked up two new seals from Nissan and am about to go and install them. From factory it appears nissan use some gasket maker around the outside face of the seal, is this something that is usually done? Is the gasket maker applied on the seal which is then pushed onto the end of the cam, or is this something to be done before the bearing shell is torqued down to make sure all excess gasket maker is removed?
Thanks for your help :blink:
https://www.sau.com.au/forums/topic/302473-gasket-goo-on-cam-front-oil-seals/
No, Nissan do not use anything around the cam seals.
I use 3bond around them anyway to be safe as it doesn't hurt
The only sealant that goes there is under the front corners of the cam cover gaskets. If you don't have sealant there or have removed the sealant blobs from the front, then that is where your leak will be coming from. It also doesn't help to be dodgey and not replace a $5 seal.
small dob on each side of the cam caps (you will see a small groove on the outside front edge, the sealant needs to be placed outside this groove)...then another small dob in the corners when putting the cam covers on...never had one leak.
hey guys! i've been having this problem for a while! , i went and brought 2 new rocker gaskets... i put them on and its still leaking oil, what do you guys recommend to do? put a little bit of gasket goo around which part????
+1 Paul is spot on here, i had leak issue and kept throwing on new seals and still leaked, then realised its coming out the little corners of the front cam caps, just chuck a dob of goo on each corner side and therefore its totally sealed, its easy to work out where the nissan seal is gonna seal and the gap between the cam cap and the rocker cover seal will seal, then theres that little section where there is no seal from inside to outside at all on the corner edges.
Edited by unique1
Yeah, I ended up going ahead last night.. used some goo around the outer edge of the gasket and a tiny drop under the cam caps (This is where it was from factory..), took her for a bit of a burn just then and no leaks thus far.. touch wood! :blush:
It's supposed to go between the gasket and the corner of the first cam cap. If you put it anywhere else on the sides of the cover it will end up leaking again. The rubber needs to bite into the aluminium and the silicon prevents it from doing so. It is necessary to have it in the front corners though. You don't need to have it under the cam caps but putting it there doesn't hurt unless you cover the oil seal return holes.
where? could you show me in the pictures? im confused...............
How is it not easy to understand? The location has been spelt out about 5 times already.
Front of cylinder head
Front cam cap
Corners where cam cover seals have sharp edges
Put silicon on the cylinder head in those corners.
Or another way to explain it:
Take off the cam cover, look at the very front of the seal on either edge of the archway. Where the sharp corners of the seal are, put silicon on the head where those corners sit.
The oil seals on the front of the camshaft: put some silicon on the outer edge and some grease (rubber or other it doesn't matter) on the sealing surface.
Oil leaks gone
There is no half moon at the front...only at the back.
Is this a prank call?
he is refering to the no.1 cam cap...but we all know the 1/2 moons are the rubber bush fitted to the rear of the head. Bad choice of word only.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
