INTIMA STREET / RACE SERIES ULTRA HIGH PERFORMANCE BRAKE PADS TO SUIT MOST MODELS. (If its not listed below then let us know)!!
SS Series info:
Application:
Street use in Standard, Performance & 4WD vehicles (Dust & Noise Free)
Description:
Making use of metal free, supreme organic materials, the SS-2100 Series provide excellent stopping power with reduced pedal effort from a cold start and will sustain this performance to temperatures up to 400°c.
Due to these materials used, dust and noise are not a problem and these pads are extremely kind to brake rotors.
Specifications:
Heat Range: Effective Braking 0°c - 400°c
Average µ: 0.55~0.6
AMECA CERT CDGE CODE: TBT SS21T GG
SR Series info:
Application:
Performance Street, Circuit Race & Drift Track Use (Low Dust & Hi Temp 700°c)
Description:
Intima's range of SR-6300 brake pads provide stable braking through the entire temperature range and have superior fade resistance. These pads are for the driver who wants confident braking on the street and on the track. The SR-6300 brake pad provides this confidence by having excellent braking capability up to 700°c. These pads also have a very low dust output and a 100% organic (NAO) formula.
Specifications:
Heat Range: Effective Braking 50°c - 700°c
Average µ: 0.4~0.5
AMECA CERT CDGE CODE: TBT SR63T GG
100% NAO Formula
SR-D Series info:
Application:
Competition, Circuit Race & Drift Track (Not designed for road use)
Description:
The Intima Type D are an exclusively formulated brake pad designed solely for the race track at a much more affordable price that many of our competitors products of the same performance.
The Type D pads have an incredible stopping power up to and exceeding 850°c and will take a large amount of punishment.
Specifications:
Heat Range: Effective Braking 250°c - <850°c
Average µ: 0.45~0.6
100% NAO Formula
FRONTS:
SUITS SKYLINE (89-01) FRONT CALIPERS (PAIR):
R32 GTST
R33 GTST
R34 GTT
SUITS SKYLINE GTR (89-01) FRONT BREMBO CALIPERS (PAIR):
R32 GTR
R33 GTR
R34 GTR
R32 GTST
R33 GTST
R34 GTT
INTIMA SR-D STREET RACE SERIES - TYPE D (FRONT) - $175.00 DELIVERED - Addtocart.gif
R32 GTST
R33 GTST
R34 GTT
INTIMA SR-D STREET RACE SERIES - TYPE D (FRONT) - $240.00 DELIVERED - Addtocart.gif
R32 GTR
R33 GTR
R34 GTR
REARS:
SUITS SKYLINE (89-01) REAR CALIPERS (PAIR):
R32 GTST
R33 GTST
R34 GTT
SUITS SKYLINE GTR (89-01) REAR BREMBO CALIPERS (PAIR):
R32 GTR
R33 GTR
R34 GTR
INTIMA SR-D STREET RACE SERIES - TYPE D (REAR) - $150.00 DELIVERED - Addtocart.gif
R32 GTST
R33 GTST
R34 GTT
INTIMA SR-D STREET RACE SERIES - TYPE D (REAR) - $190.00 DELIVERED - Addtocart.gif
R32 GTR
R33 GTR
R34 GTR
- The link next to each item will take you to our site where you can view pics & details and where you can purchase & pay via paypal with our secure online checkout system.
We also take direct deposit, bank check or money order. Please PM me or see here for details.
Please PM or contact us if you have any questions regarding these items.
Cheers,
Paul. :)
www.performance-wise.com
www.performance-wise.net
www.yellowjacketscoilpacks.com
https://www.sau.com.au/forums/topic/302501-intima-performance-brake-pads/
  • 10 months later...
  • 1 year later...
Would any rears suit R33 GTS?
I have 3 different types available. The SS series, the SR series and the SR Type-D series.
http://performance-wise.com/page23.htm
:cheers:
From what i can see, there isnt a R33 GTS compatible one. The only one there that seems it might be is the R32 GTS (RB25DE) Rears, will those fit my R33 GTS RB25DE??
Sorry, I misread your first post.
I only have the rears to suit in the SS formula (Part number IN1144).
They are listed on this page - http://www.performance-wise.com/USERIMAGES/procart40.htm
I have a couple of sets in stock, ready to send out.
:cheers:
  • 1 year later...
  • 7 months later...
  • 2 months later...
  • 4 months later...
  • 3 weeks later...
Hi, il be after a set of intima ss pads to suit R34 Gtt rear soon, are they available and what is the cost?
Cheers
We have heaps available and the total price is $90.00 delivered courier.
:cheers:
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
