GRAB A BARGAIN! NOW $6 000 !!! (firm on price)
Due to a lot of responses and negotiating on this car and i can't keep track,
I'm just going to put the LOWEST PRICE that i'll sell the car for. So, any buyer that hand over cash to me first, i'll sell the car to that person.
$6 000 !! (firm on price)
Bought this car off a dealer (still got paperwork) and Have had this car for over a year now. ALWAYS garaged and well looked after.
Oil change every 5000-6000kms with Motul 4100 turbolight oil.. Car is in good condition.
REASON FOR SELLING is i bought a S15 and rarely
drive the R32 anymore so i decided to put it up for sale.
MODS on the car:
-URAS front bar
-DMAX 30mm wider front fenders
(refibreglassed on top of original layer which cost me $200)
- 6000k HID
-Custom headlights
-Custom bezel dash cover
- Glow EL dash lights
-Intercooler
- K&N Air filter
- New heavy duty battery (century)
- Turbo timer
- Razo gear nob and pedals
-Greddy boost gauge
-AMP
-JVC mp3 player
-Aftermarket Jap Exhaust
-Electric Sunroof
extras that i will give to the buyer:
- Stock front guards
- Front Strut bar (not installed but can install for the buyer)
Car is mechanically A1 NOTHING WRONG WITH IT.
just want a quick sale as i have 2 cars.
PRICE DROP !!
Now only $6 000 (firm) CHEAPEST AROUND
INSPECTION WELCOME
David 0432 714 894
Carsales link for pictures:
http://www.carsales.com.au/all-cars/privat...id=125B1C5B1620
https://www.sau.com.au/forums/topic/302507-r32-gtst-6-000/
keen on swaps?
VT V6 Fac Manual 5spd, has had new Xtreme Heavy Duty clutch fitted 500 kays ago, new belt, tensioner, water pump, power steer pump, new engine mounts, inner and outer conrol arm bushes, adjustable castor rod bushes, Machanicals in A1 condition, alwayz serviced 5000 kays or less. VY SS 18s very good tyres, Pedders touring front and rear springs, Lukey extractors, cat back exhaust system one lukey muffler, FULL WH Statesman Tan Suede interior, PWR Windows, FULL Electric Drivers AND Pass Front seats, , Ice cold air, just regassed it.
https://www.sau.com.au/forums/topic/302507-r32-gtst-6-000/#findComment-5019376
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
    • I only use rubber also. I have an intense distrust of silicone for coolant.
    • Clamp meter will probably tell you lies. PWM DC looks a bit like AC (because the voltage is going up and down rapidly), but it is not AC because the voltage never goes negative and the current never reverses direction. But because it looks like AC, and it is happening at high frequency, at can cause wierd reactive effects. Just be warned that you might learn things that are....confusing. Because they aren't necessarily real.
    • Appreciate the detailed response! It's all new technology to me and your suggestion for reducing DC and finding sweet spots seems like a great approach.   I'll chuck a clamp meter on it at the same time and figure out whats happening at different settings to get a good understanding.   Will report back with my findings when I get around to it to help anyone in the future that will be in the same situation as me 😁
