HKS, need I say more. I have this one with a NTK Lambda sensor and mild steel trust front pipe to a high flow metal cat and the rest is a silent exhaust.
Be done with it, even if it costs u a bit more. My car was doing weird shit at idle until I changed the dump, lambda, did the aac valve and idle reset and changed the plugs and coilpacks with acouple of mates.
Nengun is your friend $325 but they sting u for delivery and time.
There is better quality out there and the topic of bellmouth to front or and the front/dump combo- you get what you pay for really.
DIY bro if you are just replacing your dump easy once you get the heat shields off, tricky space for bid hands dudes ,need deep socket too also long nose pliers. Worth it. After a fresh 100k service ,new factory gasket kit, heavy duty belt, fuel pump, N1 water pump, plugs, fuel filter the bus was alot better, alot alot better.
And I havent boosted up the car yet- im saavn for ecu &dyno time money atm or still opting to sell.
Cheapish and good quality, good gaskets, no leaks and def do the O2 sensor and thats it.
No you have to assume this is for S1 and S2
If you look elsewhere on their site the entries for Blitz mirrors that of the Just Jap -
one for the R33 and Stagea 96 - 01 (i.e. S1 and S2)
and another for R34 Skyline. Neither Blitz nor Just Jap list the Stagea with their R34 front pipes.
If its not a perfect fit for the S2 Stagea you have to assume that its a better fit than the R34 Skyline one (the R34 has a shorter wheelbase than the R33 so it is quite conceivable).
Gah... My heads spinning around now.
I dug around the garage and found a mild steel Bell Mouth Dump Pipe.. :D Must be a left over? :cool:
I rung the shop who did my cat back system (far from HKS ingineering but does the job quite fine :happy: )
asked them IF I bolt this Dump up and drove it down to the shop with just the Cat + cat back on the car (so no front pipe) they could make a front pipe to suit for under $100. So considering front pipes start at $80 and sky rocket in price from there, I figured not a bad deal, plus no chance of her rubbing.
Ps: Yes, I'll secure the system good and tight to prevent it falling/swinging and I'll have to do an early morning dash, as to avoid police and old people, considering it'll be a wee bit noisey :D
hahahaha, i've done something like that before, just make sure there is nothing the exhaust gas will melt lol. a custom front/dump like that is probably the best way to go. its basically what i did, and as you said, no clearance/rubbing issues. can you split the cat back section so you can fit it in the wagon? or is it a one piece? i don't think there is much to secure to up near the cat.
Edited by QWK32
Yeah I know the 'Awesomeness' of C.E.S but damn..$$$! I'm not chasing every last Kw the Neo has hidden inside. So any form of Aftermarket dump & front is better then the factory dump.
Well, my plan was to bolt the dump up with a new o2 sensor. remove the Front and Cat (it still retains a compliance Cat.) and get some welding rod and bend it up to secure the Cat back section to the Trans. Cross member or something near by.
Also, Yes the Cat back section is 1x piece :thumbsup: so no real other options. Other then trailer it.
  • 1 year later...
digging up an old post here.
so if i was was buy a dump and front pipe (or dump/front combo pipe) i would have to get one to suit R33?
if so will it bolt up to the standard cat in standard location? (if no, then given the length different would a R34GTT front pipe be the go?)
anyone with an RS4S got an issue with clearance with any of these pipes?
cheers
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
    • I just try to entirely stay away from ladder now unless it's something basic maintained by electricians. Even then and to your point, it mostly ends up being blocks I wrote in structured text.  PLC's are slowly going towards C, C++ and C#. I just wish Allen-Bradley would jump on the bandwagon.
