We are proud to offer Skylines Australia the worlds best priced performance coil packs.
These are proving to be very popular in Australia and Overseas and have been on the market for around 8 years now with some very impressive results.
Here is what one of our happy customers had to say about them:
I've been running these Yellow Jackets now for 3 months in my R33 GTR. Still no problem with spark blowout as I previously did with the old coils, and still plenty of power!
Done 2 HARD track days with no problems at all. Even added extra timing. Now at 28deg at 8000rpm WOT! Over 320+kw now!
I have now bought a second set of Yellow Jackets for a mates R32 GTR which had a constantly changing misfire, even after gapping the plugs to 7mm and replacing them. He wanted to upgrade the turbo's for higher boost, so I said he would have to change the coilpacks. He was dubious that this would fix ALL his problems, so the turbo's were fitted. No improvement of the misfire after installing the turbos, running them in and resetting the ECU. So I fitted the coils, gapped the plugs to 1.1, and reset the ECU. He didn't believe me that this was going to work, but low and behold, smooth idle, acceleration, and cruise!
He couldn't believe the difference in the 'seat of your pants' feel in acceleration (stock boost).
Going to do a dyno run soon to see what the difference at stock boost is compared to original figures. Then a re-tune and add a boost controller.
Bang for buck, these Yellow Jackets cant be beat!
Unfortunately, out doing a "road test" in the R33 GTR, with the street tires, and now with bucket loads of extra torque, managed to break second gear. Same sort of use/abuse with the old coils packs couldn't produce the same 4 wheel power slides, just under heavy acceleration!
Luckily I had a spare gearbox, so I could make it to the track days.
Why pay twice the price for the same results........
BENEFITS:
- Increase in torque.
- No spark blowout at higher boost.
- Improved throttle response and smoothness.
- Increased Ignition Performance.
- Improved Combustion.
- Direct Fit.
- 2 year Warranty.
- Solid Construction.
- Cost effective.
SATISFACTION GAURANTEED
Manufactured with Components from GE (USA), BASF (Germany) and Epoxy Resins from Switzerland.
EXCLUSIVE ONLY TO PERFORMANCE-WISE
YELLOW JACKETS COIL PACKS PRODUCT RANGE:
YELLOW JACKETS COIL PACK SET - YJ-RB202526-S1 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 6.
- DIRECT REPLACEMENT FOR THE FOLLOWING NISSAN RB MODELS:
SKYLINE R32 GTS-YHR31/HCR32/HR32-RB20DE (1989>92)
SKYLINE R32 GTST/4-HCR32/HNR32-RB20DET (1989>92)
SKYLINE R32 GTS25-ECR32/ER32-RB25DE (1991>93)
SKYLINE R33 GTS Series 1-ENR33/ER33-RB25DE (1993>95)
SKYLINE R33 GTSTSeries 1-ECR33/ER33 RB25DET (1993>95)
SKYLINE R32 GTR-BNR32-RB26DETT (1989>94)
SKYLINE R33 GTR-BCNR33-RB26DETT (1995>98.)
STAGEA WGNC34 (AUTECH)-RB26DETT (1997)
CEFIRO A31/CA31-RB20DE (1990>92)
CEFIRO A31/CA31-RB20DET (1990>92)
CEFIRO LA31-RB20DE (1990>94)
CEFIRO LA31-RB20DET (1990>94)
CEFIRO LCA31/LNA31/NA31-RB20DET (1990>94)
CEFIRO EA31/ECA31-RB25DE (1992>94)
LAUREL HC33/HCC33-RB20DE (1991>93)
LAUREL HC33/HCC33-RB20DET (1991>93)
LAUREL HC34-RB20DE (1993>94)
LAUREL EC33/ECC33-RB25DE (1991>93)
LAUREL GC34-RB25DE (1993>94)
LAUREL GC34-RB25DET (1994)
LAUREL GCC34-RB25DE (1993>94)
LAUREL GCC34-RB25DET (1994>)
CLICK HERE FOR BANK DEPOSIT OR MONEY ORDER
YELLOW JACKETS COIL PACK SET - YJ-RB2526-S2 - AU$400.00 delivered within 2-3 business days - Addtocart.gif
SKYLINE R33 GTS Series 2-ENR33/ER33-RB25DE (1995>98 )
SKYLINE R33 GTST Series 2-ECR33/ER33-RB25DET (1995>98 )
SKYLINE R34 GTR-BNR34 - RB26DETT (1999+)
STAGEA WGC34 (2WD)-RB25DE (1996>97)
STAGEA WGNC34 (4WD)-RB25DE (1996>97)
STAGEA WGNC34 (4WD)-RB25DET (1996>98 )
CEDRIC/GROLIA ENY33-RB25DET (1997>99)
LAUREL GC34-RB25DE (1994>97)
LAUREL GC34-RB25DET (1994>97)
LAUREL GNC34-RB25DE (1994>97)
LAUREL GCC34-RB25DET (1994>97)
LEOPARD JENY33-RB25DET (1997)
YELLOW JACKETS COIL PACK SET - YJ-CA18 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 4 WITH 4 HARNESS ADAPTORS.
- DIRECT REPLACEMENT FOR THE FOLLOWING CA18 MODELS:
BLUEBIRD U13-CA18DE
BLUEBIRD U13-CA18DET
EXA N13-CA18DE (1987>91)
EXA N13-CA18DET (1987>91)
SILVIA S13/KS13-CA18DE (1988>91)
SILVIA S13/KS13-CA18DET (1988>91)
180SX RS13/KRS13-CA18DET (1989>91)
YELLOW JACKETS COIL PACK SET - YJ-RB20313233 - AU$420.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 6 WITH 6 HARNESS ADAPTORS.
- DIRECT REPLACEMENT FOR THE FOLLOWING RB20 MODELS:
SKYLINE HR31-RB20DE (1985>89)
SKYLINE HR31-RB20DET (1985>89)
SKYLINE YHR31/HCR32/HR32-RB20DE (1985>89)
CEFIRO A31/CA31-RB20DE (1988>90)
CEFIRO A31 CA31-RB20DET (1998>90)
FAIRLADY Z PZ31/PGZ31-RB20DET (1985>89)
LAUREL HC32-RB20DET (1986>91)
LAUREL HC33/HCC33-RB20DE (1988>91)
LAUREL HC33/HCC33-RB20DET (1988>91)
YELLOW JACKETS COIL PACK SET - YJ-RB2025-N - AU$400.00 delivered within 2-3 business days - Addtocart.gif
- DIRECT REPLACEMENT FOR THE FOLLOWING RB NEO MODELS:
SKYLINE R34 GT ER34/ENR34 - RB25DE NEO (1998+)
SKYLINE R34 GTT ER34 - RB25DET NEO (1998+)
STAGEA WHC34 - RB20DE NEO (1997-1998)
STAGEA WGC34 (2WD) - RB25DE NEO (1997+)
STAGEA WGC34 (2WD) - RB25DET NEO (1998+)
STAGEA WGNC34 (4WD) - RB25DE NEO (1997+)
STAGEA WGNC34 (4WD) - RB25DET NEO (1998+)
CEDRIC/GROLIA ENY34 - RB25DET NEO (1999+)
LAUREL HC35 - RB20DE NEO (1997-1998)
LAUREL GC35/GNC35 - RB25DE NEO (1997+)
LAUREL GC35/GCC35 - RB25DET NEO (1997+)
YELLOW JACKETS COIL PACK SET - YJ-SR20-S2 - AU$310.00 delivered within 2-3 business days - Addtocart.gif
- COMES IN A SET OF 4.
- DIRECT REPLACEMENT FOR THE FOLLOWING SR20 MODELS:
SILVIA - S15 - SR20DET - 1999-2002
X-TRAIL GT(Jap Spec) - SR20VET - 2002-2007
- The link next to each item will take you to our site where you can view pics & details and where you can purchase & pay via paypal with our secure online checkout system.
We also take direct deposit, bank check or money order. Please PM me or see here for details.
Please PM or contact us if you have any questions regarding these items.
Cheers,
Paul. :)
www.performance-wise.com
www.performance-wise.net
www.yellowjacketscoilpacks.com
  • Replies 46
What makes a S14/S15 coil pack different to all the other Nissan's
Cheers
Mainly size and fitment and also internal and operating characteristics.
The S14 and S15 coilpacks are also different from one-another.
:huh:
What is it exactly that makes the internal operating charcteristics in a S15 coilpack different to some of the other Nissans?
Im not 100% sure at this point. I know mounting positions are different.
How did you manage to make coil packs for all the other nissans and then got stuck on s14/s15?
We havent gotten stuck on the S14/S15s, just havent gotten around to it yet and there is more demand for the Skyline types so they have been our priority.
  • 10 months later...
S15 Yellow Jackets will be ready in around 1 week... woohoo.
Now sold over 800 sets worldwide and counting. Thanks to all who have purchased :cheers:
  • 1 month later...
hi are these still at the same price? and do ytou have any fro a R33 S2 GTST in stock?
Yes, prices are the still the same and have all types in stock.
:cheers:
:cheers:
ill take a set for a r33 series 1 skyline ive tryed to contact you but i cant get though pm me back or call me on 0438652804 thanks Allan
PM sent :cheers:
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
