Hey guys,
Happy New Year.
Quick one, when you order a bumper from Nissan Japan, can you get them already painted in your correct colour from the factory?
I'm 92.5% sure the answer is yes, but just wanted to double-check as a dealer is giving me the "not my fault I ordered the wrong part number".
Cheers.
Thanks Chris,
You mean you think it comes in primer? Well the rear bumper I just got is actually painted pearl white.
When I bought my front aero bar a few years ago, in Fast there is a different part code for each colour. I ordered the part number for my car and the bar came painted from the factory correctly.
This time I left it to the dealer after a recent accident and they've ordered the part number for a white bar. Now they are telling me that is the only colour they can get, even though they didn't order the correct part number.
So before I go any further, I just want to double-check with a few others that have had accidents.
Thanks Chris,
Last time when I get accident, I order a new front bumper and passanger side front quad fender. The bumper came with factory silver paint. the fender does not. No idea why. I assume the bumper is plastic so Nissan think their facotry can do painting job better?
Ok thanks Frank,
Just checked and what your saying sounds right, as there is not a separate colour code for each part for the metal fender in fast. Wheras with the bumpers there is.
Thanks for replying.
When I was looking for the plastic that surrounds the indicator/fog light, the spares department also asked for my paint code so they could order & paint it to match.
So failing all else it seems they should be able to paint it in original colour.
Ok thanks Frank,
No problem mate.
Glad I can help.
BTW, 1 weeks after my repair job completed, My smash repair shop call me said: the demaged bumper I replaced ( Not the bad damaged, still repairable) has been stolen from shop's rubbish bin. The shop owner was very surprised that how popular this bumper is, someone even would to steal a damaged one. LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
