Hey Guys.
Selling my bumpers and side skirts.
If anyone can do a pick up i'll sell the lot for $200.
If i have to post $330 + the cost of posting for the lot.
Individualy: Front bumper $150 + post
: Rear bumper $150 + post
: Side skirts $100 + post
The kit is in ok\good condition. There are no cracks but some deep scratches under the front bumper. You can't see them unless your bending down.
All other marks might come out with a buff. :D
But none of that matters if you need to paint it :D
I have taken pics of all worst damage.
  • 4 weeks later...
OK. With "Toll I PEC" $190 for each bumper and $80 for side skirts. That's to Perth and the same to Sydney.
If you bought them all i would send in one package and it would cost at a guess $200 for the lot.
So it's about $530 for the lot to send to Perth or Sydney.
If you live in Perth it would be cheaper to drive here and pick them up yourself. Since i'll sell the lot for $200 pickup only.
  • 3 weeks later...
Hey Paul, can you please get a shipping quote for the front bar to Northgate, SA, 5085? Pretty keen, since I have toasted my stock bar mounts
it would be $190 to get it anywhere in OZ. But when you say "Bar mounts" do you mean just the bumper becasue thats all i got
Yeah I only need the bar mate. Can you get a specific quote for me, as if it is $190 to anyhwere in Oz (Qld for example) then surely it is half that amount to get it to Adelaide which is 1/3 of the distance.
It's the same to send to Perth and to Sydney so it would be the same to Adelaide. They told me it don't matter the distance. Thats with "TOLL I PEC". You can use any courier you want and get them to pick it up or tell me where to drop it off localy.
I can double check tomorrow. :)
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
