Hi All,
I have been doing research here and there, and it seems Mitsubishis incorporate lean spool by factory. Their ECUs are so powerful in comparison to ours, dual maps (lo & hi octane), lean spool features, etc.. ra ra ra...
BUT I own a Nissan and I love them, enough of the crap ;)
I have been re-tuning my car here and there and I would like to see how others have their A/F set vs Spool.
Currently, I've played with my PowerFC and when the car comes onto boost it's quiet lean, on full boost A/F is around 11.7~12 which is safe and timing is at 13 degrees @ 18PSI, for some reason when I dial in even 1 extra degree I get retarted knock on a 30degree day, but at 13 degrees its fine, knock no more than 30.
So, could everyone post up their Boost vs A/F graphs? that would be great.
R31Nismoid, YES I have looked in the RB25 Dyno results. Mainly its all Power Graphs which I'm not interested in. :banana:
Sorry, I'm trying to establish what you are trying to determine - you mention spool but it sounds more like you are trying to work out why you are knock limited when trying to add timing at 18psi of boost?
I assume you are road tuning? Bare in mind not all things are equal with different cars, an obvious which would apply to your example would be turbo choice. If your car is experiencing high exhaust manifold pressure then you will be able to run far less timing than if you have no major restriction on the hot side. Same would good for good intake charge quality (good intercooling, not maxed out compressor, WMI etc...).
I have no AFR graphs for my car printed, but am targetting similar afrs - ranging from Stoich at very light load to around 11.6 at full (17ish psi on an RB25 running a GT3076R) boost.
Edited by Lithium
I agree, since i started playing with late model evo's, my thoyughts on spool a/f have changed. I no linger have any dramas tuning my cars to run 14.5 at 2psi, and 13.5 at 5 psi, this is dependent on the car and mods though obviously.
Hi All,
BUT I own a Nissan and I love them, enough of the crap :)
R31Nismoid, YES I have looked in the RB25 Dyno results. Mainly its all Power Graphs which I'm not interested in. :blush:
um nissan has had all that for decades also...
agreed, mitsu is factory tunable. evo 7 and up needs no modification PERIOD to be tuned. plug in and go. earlier models require a 7+ ecu and a minor re-pin, even the earlier models with the different motor. no less than excellent.
Yet I wonder, what would happen if you dropped the AFR to something a little richer and then tried to add the timing. Considered this?
Sorry trent, would have to disagree on this one, mitsu ecu's are far more powerful than the nissan rb ecu's.
SInce when does nissan have lean spool, which is an rpm/time/load dependant feature, active(knock monitered) ignition mapping on individual load points, and a total knock count ingition map trim?And mivec of course
what do you think is causing the knock?
do you think its the AFR's?
do you think its the intake temp?
do you think its the ign timing?
why do you need to run 18psi?
is your compressor efficient at that level
turbochargers once out of the efficiency island give diminshing results, that is, for every psi extra you dial in, you dial in assloads of hot air
the more hot air you dial in, the more the engine detonates
so - reasses - is 18psi efficient and giving you good gains, ie from 17 to 18psi do you gain 10kw or do you gain 1kw?
omg, I just read what I wrote, didn't make sense! trying to multitask at work, failed!
Forget about what I wrote about full load, I'm quite happy with the result I got, I'm just working on getting the boost to come on earlier.
anyways, what I am actually after is the A/F everyone runs when coming onto boost. I know the leaner the harder it will spool due to exhaust gases.
Paulr33, FYI I'm running HKS2535 and supporting mods, so chillax I'm not running a stock turbo like you!
No need to lecture me about turbo efficiency ra ra ra, yes HKS2535 is rated most optimum at 1bar but many have run them at 1.3bar and get quite outstanding results, such as Robo, and a few other people
So what I am after mainly are dyno graphs which have the boost vs a/f ratio pre full load
remmeber compare apples to apples ie year model to year model, the early evo stuff is pretty clunky also. Most of what you post is tweakable with aftermarket mapping gear.
lean spool = R32 gtr ecu feature
active(knock monitered) ignition mapping on individual load points= r32 gtr std ecu feature
total knock count ingition map trim= r32 gtr std ecu feature
mivec= nissan fail :) not till much later
the mitsy stuff of the same era (1990) was no better but if your comparing evo 6 onwards than yes they are a better beast.
to be honest the best stuff around is the holden (ls) and ford (fg) gear there is more features than nissan and mitsy combined (current r35 excluded)
somethings going on with that power curve .
knock knock whos there?!
and isnt 10psi and 15:1AFR at 3250rpm bad mmkay? thats just asking for EGT issues IMO...
nah the ramp afr's are pretty much ok, remmeber there is a lag between engine and tail pipe and a cat, so i reckon its closer to 13:1 and 5-6psi.
Trent from your experience, what A/F ramps are safe? do you have a graph I can look at?
Also, I notice I mainly get knock off lift off, why's that? there's no explanation on the web! I tried to alleviate the problem by dialling in more fuel and pulling back timing, it just results in FLAMES on the overrun LOL
i get random knock spikes at the exact point i lift off too, havent worried about it too much. use it as an excuse to keep going through to limiter :)
last worshop tune i got was on the very safe side and started at 14:1 at 2psi then linearly down to 11.5 at peak torque at 17psi, then back to 12:1 for the rest of the way. was 13:1 at around 6-7psi
Edited by JonnoHR31
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
