i have for sale a 2way nismo diff center with one half shaft and it will need one more i was told by the guy i brought it off that it needs r34 half shafts .the center was never fitted to my car (i went shimmed instead)but as far as i know its in good condition ..
$350 firm and pick up only
to contact me just post in this topic or pm me :banana:
https://www.sau.com.au/forums/topic/302572-nismo-2way-diff-center/
so if it needs r34 shafts it should be direct fit for r34 gtt correct??
yeah im pretty sure it came out of a r34 but i can find out off the guy i got it from .
how many spline on output you have,
which DOES plug in properly you are saying??? yes??
What dia are the 10 holes for the crownwheel??? 12 or 13mm???
for the above poster, it has no ratio as it has no crownwheel fitted, the teeth count between the crownwheel & pinion is what gives you the diff ratio, ie swap on your own crownwheel to maintain your ratio....
nat0
nat0
yes the half shaft i have fits in and i will check the number of splines and measure the holes and post it up ...hey mate thanks for the help :blink:
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
