1990 NISSAN SKYLINE R32 3LTR
THIS CAR WAS A GTS4 WHEN I FIRST BOUGHT IT THE RB20 THAT WAS IN IT EVENTULLY LET GO
SO I HAD A GENUINE VL TURBO RB30ET MOTOR WAITING TO BE PUT INTO SOMETHING SO IN IT
WENT. THE MOTOR WAS RE FRESHED WITH NEW RINGS AND CRANK BEARINGS, CRANK WAS RE LINISHED,
HEAD WAS CLEANED UP BASICALLY THE MOTOR WAS REFRESHED. ITS RUNNING A ACL RACE GASKET ON
THE HEAD I HAVE ANOTHER CAM THERE FOR IT BUT IT IS NOT CURRENTLY IN IT, THE PLENUM IS A MOCK
JOB OF NIZPRO WITH XF THROTTLE BODY. INJECTORS ARE 750CC BACKED UP BY A 500HP FUEL PUMP, THE
TURBO IS A GARRET GT 35/40 WITH STRAIGHT THROUGH 3 INCH EXHAUST SYSTEM, ITS RUNNING THE
MICRO TECH LT-10S COMPUTER WITH BUILT IN 3 BAR MAP SENSOR NO HAND CONTROLLER. IT HAS A
ELECTRONIC WATER PUMP INSTALLED TO KEEP EVERYTHING FLOWING NICE ASLO HAS RB20DET OIL PUMP
INSTALLED. THE GEAR BOX IS A RB25 WITH BUTTON CLUTCH BUT IT HAS JUST RECENTLY BLOWN 3RD GEAR
SO IT WILL NEED TO BE REPLACED OR REPAIRED. THE CAR MADE 241.3KW @WHEELS WITH 10 POUNDS THE
THE TACHO AND SPEEDO DO NOT WORK AS DIFERENT BOX WENT IN APART FROM THAT THE MOTOR IS A GOOD
STRONG PIECE OF NISSAN TECHNOLOGY I AM ASKING FOR $14,000 WILL COME WITH 12 MONTH REGO
https://www.sau.com.au/forums/topic/302590-r32-3ltr-rb30et/
