Heya Just got my car back from a service an the report says need castor bar bushes perishing.
What aftermarket ones can i replace them with and are these called something different?
Like Caster adj kit-radius rod bush or Bush kit-rad rod to chassis?
Also im looking to replace my coilovers bcos 1 Adjuster is damage. What would be good for traveling over distance not for track use just a daily use.
Cheers
https://www.sau.com.au/forums/topic/302592-castor-bar-bushescoilover-qs/
I highly recommend a set of bilstein B6's for a daily ride. some tein or king springs would go with it, should be an off the shelf match. These will also work well with standard springs.
Whiteline or superpro make an adjustable bush kit. I recommend this over an adjustable arm, as you said, daily not track car.
depending on location, you could use
Centreline Suspension
72 Lipton Drive, Thomastown
PHONE : 03 9469 2914
FAX : 03 9460 7215
Quadrant Automotive Suspensions (Aust) Pty Ltd
63-65 Intrepid Street
Berwick, Victoria, Australia, 3806
Ph: 03-9768-9109
Fax: 03-9768-9173
Email: [email protected]
Web: http://www.quadrantsuspensions.com.au
Traction tyres
http://www.tractiontyres.com.au/
65 Kelletts Rd
Rowville VIC 3178
(03) 9764 2811
GT Suspension
137 Mt Alexander Rd Flemington VIC 3031
(03) 9376 0777
