FOR SALE:
-Specs-
-Nissan Skyline R32 GTR 1994
-Sonic Silver
-132000kms
-Sonic Silver
-5 Speed
-Engine-
HKS GTSS Turbo's
HKS Turbo Actuators
Z32 AFMs
NGK Iridium Spark plugs
HKS TOP SECERT Adjustable Cam Gears
GREDDY Timing Belt
NISMO Fuel Pump
SARD 700cc Injectors
SARD Fuel Rail
SARD Fuel Regulator
TOMEI Intake Manifold Gasket Set
NEW GENUINE NISSIAN Turbo + Manifold Gasket set
APEXi Pod Filters
TRUST Clear Cam cover
N1 Oil Pump
NISMO Engine Mounts
High Octane Oil Catch Can
-Drivetrain-
Exedy Heavy Duty 6puck Clutch
-Brakes-
DBA 4000 series slotted rotors (Front and Rear)
RB74 Pads
-Electronics-
TRUST Profec B Boost Controller
Apexi Power FC
4wd/2wd Switch
HKS Turbo Timer
-Suspension-
Tein - Flex, 32 way Damper + Height Adjustable Coil Overs
NOLTEC Front Upper Control Arm Bushes
WHITELINE Radius Rod Bushes
WHITELINE Rear Subframe Pineapples
NISMO Front and Rear Strut Braces
-Exhaust-
MINES Dump Pipes
HKS 3" Front Pipes
High Flow 3" Cat
TUST PE II Cat Back Exhaust System
-Wheels-
R32 GTR Wheels
Falken Azenis RT215 Tyres (65% Tred)
-Extras-
NISMO Urethane Shift Knob
N1 Headlights
NISMO Oil and Radiator Caps
Clarion Cd Player
Boston Front and Splits
Pioneer Rear Speakers
The car was imported stock and has two folders of receipts for all the modifications it's had in Australia.
It's had no accident history and the body is clean. There's the usual steering wheel and drivers seat wear, The only damage is the scrape and crack on the front bar. They were there when i bought the car but never got around to repairing it. This GTR was detuned to 360hp ive got Dyno sheets, but is good for 450+ HP, Currently the car is located in Perth, Western Australia but i'm willing to transport the car anywhere around Australia at the buyers expense.
PRICE: $22000
Edited by GTR-BNR
https://www.sau.com.au/forums/topic/302598-fs-1994-skyline-r32-gtr/
  • 1 year later...
Hey mate, just enquiring about this car. I don't suppose you still have this since it was 12 months ago from the last post? I actually use to own here car here in sydney and did most of the work to it actually. I'd love to buy it back! hehe
To see some photos of how it use to look check my member gallery GTR032. If you have any info on new owners please let me know.
cheers
Jono
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
