Please!! Tell Me It Aint....
  • Replies 61
Originally posted by ex-static
Im not sure if its the one, and I highly doubt it.. but one came from japan very similar to that, and it packed about 600hp at the rears...
Dont think its the one tho..
i think the one that you are talking about is the top secret one and trust me thats not it
Yo yO YO......w@ZuP FoOlS!! Th@t B'z Mah RyDe!@!............
NOT!!......haha....that car is just so wrong in so many ways.
I've seen that car at uni too a while back in its plain glorious form....the guy who owned it then had a friend who drove a 200sx in exactly the same colour sceme. he'd probably cry if he saw what's happened to it now......i know i would......more rice anyone?? :smiles:
there is a red one roaming about the S.E area just as bad...got these wierdass eyelid type stickers on its headlights.....all it was missin was a big fat firebird sticker on the bonnet...hehe...keep an eye out.....u'lll know when u see it!! hope its not anyone on this forum
Stickers... ugh. Why would you ruin your paint anyway? If you must have stickers put them on the glass... I do want to change my series II wing to the low boot wing (like the one below that massive T wing in the pic above) though... makes R33s look f-a-t.
Originally posted by INASNT
smoothline
do a search about s-afc, u will find its a good bang for your buck mod!
Mine cost me $400 second hand and about $75 to tune.
Yeah sweet... i checked out Apexi.com and it sounds like the goods to me...
And for under $500 bucks im wrapped! Thanx mate.
I can install it my under my single din head unit... nice :D
    • Ok cool, because I do have some OEM BMW options for light(er) wheels. 17x8.5 M Sport wheels are 11kg and I could put 255's on them. Maybe that's an initial test.
    • So, in the effort of pulling apart airboxes and testing enclosures to see if this aids in MAP loss at WOT I noticed: 1) The ducts up the OEM intercooler holes from the front bar help IAT drastically, whether the pod is shielded from the engine bay by an airbox missing a lid, or an airbox WITH a lid. Plus you get more induction sound without the lid. Having half the airbox (with no lid) acting as a barrier to the headers seems to help. 2) For shits and giggles I checked the TB. This was full pedal travel. This is actually full travel of the TB. Photos aren't perfect, but there was definitely an amount of play in it and it wasn't against the stop. After much swearing and adjusting the pedal, I realised that the cable is actually too long for the skyline pedal travel to fully articulate it. Having the pedal adjusted so WOT was actually hard open on WOT resulted in an idle of 3500rpm. As an aside, this was also the TPS registering at 3.1%. I removed the above to give the pedal enough travel to actually fully open the TB. I now get a satisfying 'thonk' on full open and full closed which you can hear pumping the pedal as it hits the TB stops (with the bonnet open and intake back on). Luckily for me, the screw screws into a raised metal boss under this plastic piece that is now acting as the new throttle stop. I've gained about 20mm (ish) of pedal travel and I can move it maybe a mm or two post open-thonk before it's hard against the stop. After all of this I did a bit of road tuning because a 102MM throttle is sensitive. The difference between holding an 950rpm idle and instantly stalling is about 0.4% of TPS movement. Will that help? I suppose it can't hurt. I set 'closed' point back to where it was, I can definitely feel the extra pedal travel that is needed to actually open the TB fully. But this morning I dropped the car off at Paint Jail again, so who knows when this will re-eventuate out to see if it helps with the top of the dyno hitting a ceiling.
    • Take heart that everyone else seems to have found a way. The OEM S1 indicators do slot in pretty firmly. It may simply be a case of having them sit slightly looser and nobody actually ever noticed this when attempting to remove a indicator from a JSAI bar :p
    • If the original NA ECU has a separate TCU then you are going to need to reroute wires that used to run between the trans and the TCU to the appropriate (1 to 1 equivalent) pins on the ECU. Other than that, it should work. Look up posts by @Kinkstaah on the subject.
    • So the stagea was a series 2 neo det with tiptronic auto. (I have the transmission aswell) and has integrated tcu in the ecu. I'm hoping to use the entire stagea ecu, engine and auto harness.
