problem first occurred a few months ago when i AWD light stayed on for no apparent reason, had it checked by two mechanics nad an auto electrician and they all seem to think its fine with the light on.
Got in the car today and it stayed on for about 2 sec, then turned off.
Got back in a hour or so later and started the car again and the light is back to staying on.
i cant get my head around it
i noticed again something that i noticed the first time the light decided to stay on was when turning slow out of a park space ect the front wheels feel like they keep trying to grip and it feels like a studdering motion, hard to explain.
Any ideas or thoughts much appreciated.
https://www.sau.com.au/forums/topic/302605-awd-light-jsut-turned-off/
battery is new, My mechanic and the mechanic were i got the car from both put it on the Nissan diag, was coming up with ABS problems, had a new asb unit installed and same problems, Not sure about the error code tho, im pretty sure the AWD works tho, front girps up nicely in the wet.
bump, need to get this fixed asap,
Noticed the problem again yesterday, turning out of a car park with the wheels at full lock the car make fast little jolts and shakes. And what is the Slip light for? it sometimes flickers on when its jolting.
  • 4 weeks later...
Just an update to my problem, driving home today and was testing a vibrate in the exhaust at high revs so changing at around 7-8k, then i noticed the awd light turn off, jump in the next day and light is on again, so back to the usal problem, then jumping in and staring the car this arvo the awd light flickered on and of realyl quick with a buzzing comming from the ATTESA pump in the, last about 5sec.
Had a quick chat to my mechanic and he sed its one of the solinoids (sp)? whats are they?
Edited by sydking
    • Holy hell! That is absolutely stunning! Great work!!!
