As per the title name, a mate bought some Federal 595RS semi slicks in the abovementioned size for his HR31, another mate reckons that a 40 profile is too small for the 9.5 wide rims he runs on the rear. He does have other rims if this is the case, anyone know one way or another?
Why would a 40" profile be too small for a 9.5" wide rim?
And what brand of semi-slick is this....you might be able to check tire rack or similar:
http://www.tirerack.com/tires/Spec.jsp?mak...tirePageLocQty=
With a A048 235/45 is designed for a 9" rim at most, a 235/40 might make it on a 9.5" but I think you'd want to go 245 or 255.
I'm aiming for 255-40-17 in a non-semi slick.
little skinny for a 9.5in rim. I've had that same size on a 9in rim and it was fine. It's only 1/2 inch diff. Just give it a go. Depends what they want though.
I think what he means is that a 40 profile won't stretch that much.
Yeah was a little unsure, of course its illegal lol, and well 235/45/17 tyres don't seem to be too stretched on my 9.5" rims, was more of a concern about the bead rolling off the rim. Car's not really going to be used for any serious track work or drifting, more of a quick street car.
The 235/40R17 Federal 595RS and/or 595RS-R is recommended by the manufacturer to be fitted to wheels 8.0" - 9.5" wide, so there shouldnt be any problems fitting these tyres to your wheels.
However, they may look a little stretched and will have almost no sidewall flex - ideal fitment for a 17x9.5 would be 245 or 255's.
595rs and rs-r and not semis, just sticky road tyres.
ya not sure about stretching 40's that much. federal do a r17 235x45 tho.
595RS and 595RS-R's ARE considered semi-slick tyres, not only by the manufacturer but by CAMS (Confederation of Australian Motorsports).
The term "semi-slick" simply means that the tread pattern has a lower void ratio than that of a "normal road tyre".
You are probably suggesting that these tyres arent "R-compound" cut slick tyres - and you would be correct... The 595RS-R is not a race compound tyre, however it has a softer compound than normal road tyres and a reinforced casing that is specifically designed to resist folding under extreme cornering loads - making it perfectly suitable for track use.
I hope this clears up any confusion :D
you may have to find a good tyre fitter as semi slicks usually have a stiffer sidewall, so they are harder to stretch (especially if they are new), and a 40 series will have a pretty low sidewall... so low and stiff sidewall = difficult... but hey, worth a try. i know of someone fitting federal 595 215/40/17 to 17x9.5 and 17x10... i think they had to use the brake cleaner + lighter method though. damn good stretch though!
it does, thanks, i thought the term 'semi slick' was synonymous with r-comp tyres.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
