As title, i have a R33 GTS-4 series 1.5 and it has just clicked over 100,000km's, it had the timing belt done 2 years ago so tahts still good, the thing im tryin to find is what fluids need to be changed, and what fluids are used.
Cheers!
https://www.sau.com.au/forums/topic/302627-r33-gts-4-100000km-service/
Nissan doesnt have scheuled intervals for passenger cars regarding diff and box
recc intervals for longevity
brake fluid 1 to 2 years,
coolant 2yrs max -box fluid will last much longer but id say 40k
auto fliud 40 k max
ps fluid, every 5 years if your keen
like anything, the more u use and abuse, more u should service it
Easy answer... Replace everything you can. I'd replace the timing belt and water pump anyway, just to be safe. Plugs, oil and filter, gearbox and diff oils, coolant, brake fluid, power steering fluid if its dirty, even O2 sensor wouldnt be a bad idea.
as NA said replace every thing.
Timng belt/brake fluid,transmisson fluid or gear oil/diff oil[any thing synthetic 75-85w], coolant, water pump if possible, spark plugs.
if im am u i normally change the power stering flud and all drive belts as well. when u change the timing belt chk the cam and crank seals for leaking or any abnormal condition. as well as tension pully and ideler if noicey replace it. most of the time these pullyes not last more than 100000 km.
Can anyone tell me what diff oils i should use and same for box (remember its AWD), im not looking for top of the line as its just a NA run-a-bout just something thats good.
