I'm currently using metal jerry cans which are starting to piss off. Leaking all of my/Duncans feet sucks let alone a scrut seeing it. Oh yea it's proberly just a little dangerous as well.
Years ago I used ex army ones bit rust took over so I went to the usual $50-60 buck Repco/Super Cheap crap,,,but they all bloody leak.
So I'm looking for a quality alterative.
Searching the interweb it seems the drag guys use plastic ones,,,but not the cheap same jerry can shape plastic rubbish.
VP fuels and RCI make what looks very good quality ones,,,but are they???. It also seems theres limited places to buy them,,,I may well get raped by Rocket ect.
Any help would be very much appreciated.
Neil.
https://www.sau.com.au/forums/topic/302630-fuel-containers/
Neil.
hey neil
i bought some rocket ones, they leak too the cap has hole in it for breathing , crap seal too.!
also if you leave fuel in them for very long especially when transporting( getting shakin around) the fuel vapour is released and you can be left liquid that is no longer really race fuel., causing misfires and injector issues.
we run sealed 20 ltr containers , 60's or 205's.
cheers russ
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5018144
I bought some cheap crap ones from bunnings for $20, and they never seal and leak all of the time.
I remember seeing some fancy ones when looking for mine for my motorbike. It has a fueling system built in so you can just tip it upside down to fill up and it wont leak.
I'll have a bit of a look and let you know.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5018274
Ballards sell them, they are called tuff jugs.
Supposed to be for motorbikes, but that's what your car is really, isn't it?
http://tuffjug.com/index.php?option=com_we...=1&Itemid=3
The idea is a quick fill system, but looks like it will be a bonus for you if it fills quick.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5018282
I bought two 1/2 decent 20L plastic jobbies from *i think* repco that I carry to track days. They have a little rubber oring on the cap and never leak even when full lying down in my boot. So far they have lasted 5 years.
As long as the actual cap thread isn't the issue I suppose you could always get an oring to seal the cap and can.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5018730
After getting sick to death of filling our sprinter with Jerry cans (fuel cell in the boot), We ended up getting a couple of empty 50 L drums from LWR, look like these. have a metal cap and the rotary hand pump screws straight into them for a spill free fill.
Be even nicer if they still had ELF in them :(
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5018819
Ditto that, and they've been ok so far. Only had them for two years though.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5018948
Thanks Guy's,,,love the responses. If I'd asked this question anywhere else I would have got rubbish reply's and would still be none the wiser. You guy's are RAD.
Russ,,,which did you buy,,,the RCI or the VP or the Jaz?.
Stuart,,,yes I pegged your's,,,where did you buy them?. Your the one that gave me ideas.
Jason they look like the ducks guts,,,.
Which brings me to a little problem I have with the Radical,,,it has no fuel gauge and no hope of ever fitting one. So what I have to do is go out with ex amount of fuel,,,drain the tank after the session and measure it. I was think the Jaz/VP/RCI ones,,,I could mark the outside and maybe see how much fuel I've used.
Boy's while the Elf cans and Rotary filler would be great,,,sadly no. Great for Tarmac stuff as you guy's need fuel dumped in quickly,,,I don't. I had a thought though,,,As some of you well know,,,I work for BMW and we get brake fluid in 30 litre drums of which are German and are of high quality. We actually do store fuel in them and they have the screw on fitting,,,we throw them away after use. These could be good for you guys.
Neil.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5019552
ill see if my rocket account is still active, been 12 months but should work.
Neil.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5020016
I still have 6 aussie made Rheem jerry cans going strong after 20 years. :D
I would be looking for good used steel fuel cans if I was you Duncan. There is a few on ebay ATM
Edited by Tektrader69
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5020047
ive got a funny feeling your not allowed or supposed to use metal containers, due to the risk of static disharge.
maybe its an andra thing and no a cams rule. i can get plenty of VP twenty litre drums if you like.
I still have 6 aussie made Rheem jerry cans going strong after 20 years. :rofl:
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5024237
I've ordered 2 Jaz white containers from Revolution,,65 bucks each,,,I'm thinking I'll order 1 more. I took a blue one out into the sunshine today and could see though it. They have a an o-ring fitted cap and a lttle breather near the handle.
Time will tell if they are better than the tin crap that leaked everywhere today.
Neil.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5025308
they will be right tiger.
Neil.
https://www.sau.com.au/forums/topic/302630-fuel-containers/#findComment-5029112
    • I don't run the spring but it means you need to set your own belt tension.  I put tensioners on both sides too.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
