for what it's worth...I'm using the steel ones Neil is having trouble with, and no problems atm. Mine have had far less use than his though. One other problem with them is 20l is bloody heavy to hold the jerry while it slowly fills....and for a skyline 20l jerrys really are not big enough (my car does about 100l/100klm at full noise).
pete - the trailer mounts are for the rectangular plastic or metal 20l jerries that neil and i have. same as the death trailer which has 4 mounts on it.
stu - no such rules with CAMS, and I'd be surprised if adnra had one considering how the jungle juice always comes in metal containers.
russ - neil already has a dipstick in the car - it sits between the steering wheel and the seat. ha ha ha.
Oh everyone loves a smartarse,,,.
Pete,,,if you are using the plastic crap that Duncan has,,,then you need to remove the wood bits and suffer the expansion,,,if you are using the metal ones then they should fit,,,but not snuggly. Seems the brackets are not made for metal cans as I have the same problem as you. they flop around like a cock in a sock.
Russ,,,ask Duncan about dipsticks,,,seems shorter dipsticks are all the rage or ask for directiions to my house,,,NOT. :banana::P:banana:
Neil.
I had the same problem.....best investment I made was a marine grade jiggler hose available at boating shops. Simply put the jerry can on the boot, one end of hose in the fuel filler - other end in the jerry and it practically fills itself :thumbsup:
Oh my god,,,you put a jerry can on the boot of a Skyline Shame on you!!!. Maybe on a commodore and a falcon but not a Skyline.
LOL Neil you won't find a more fastidious (spelling?!?) GTR owner who tracks it anywhere...just ask Mick from Micolour :P The jerry can doesn't go DIRECTLY on the boot without a suitable layer (or two) of cotton or microfibre. I can assure you that the paint hasn't been marked once.
LOL Neil you won't find a more fastidious (spelling?!?) GTR owner who tracks it anywhere...just ask Mick from Micolour :D The jerry can doesn't go DIRECTLY on the boot without a suitable layer (or two) of cotton or microfibre. I can assure you that the paint hasn't been marked once.
Okay I'll take your word for it,,,but if I ever see jerry can sratches on your boot lid,,,I'll,,,I'll...I'll cry.
These are what we bought,,,funny the yanks now mould them with "Water",,,stupid bastards. They worked a treat,,,thanks to Mr Handley and much dedate on
working out how much fuel I was using at Oran Park GP we worked out that 7 litres is about right for supersprinting,,,not 20 something. So thats about 10 to 13 kilo's or more I don't have to drag around the track.
Neil.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
