I never said it was linear.
You know what the car losses through the drivetrain from factory.
Example, the old GTS HSV Monaro's. Rated at 300kw, make about 220-240kw@wheels.
Standard GTST, rated at 180 odd kw, make anywhere from 120-140kw@wheels.
So if the same GTST makes another 110kw@wheels to 250kw@wheels, we re-add that 60-40kw loss, so it pumps it up to 290-310kw@engine. However the engine is now producing more power, therefore everything is slightly increased in loss. This is the figure that can not be given by a percentage, or a fixed linear figure. It varies. I'm sure there would be a close equation you could do to work it out more accuretly. The more power you make, the higher the additional loss through friction, fluids, heat etc.
So in a bit of a maths equation.
kw@motor = kw@wheels + original factory loss (say 50kw to be a nice number) + 'unknown variable' (additional loss as power increases)
= 250kw@wheels + 50kw original loss + 'x'
= 300kw@motor + 'x'
This 'x' value is one that you have to guess logically. It aint going to be 100kw, it aint going to be .5kw. A good educated guess in this case could be 5kw. It will obviously slightly increase with the more power you are making. at 1000kw@motor it might be 50kw.
That is about as accurate as you can get with guessing, and for most people i think it is good enough to have that minium value and a little bit extra. I'd rather under qoute something than over qoute.
This logic makes sense when making a calculated estimate.
I like to know it due to conversation with people that aren't that into cars. Since most manufacturer's qoute engine HP figures and all modified car owners qoute @ wheel figures it makes discussions with people that aren't into cars difficult.
Classic case, talk to some one that bought a brand new HSV "My HSV makes 307kw, what does yours make" "My car makes 280kw@wheels" "....Haha my stock HSV has more power". Therefore if you are talking to some one, say your friends parents or something, i always use engine HP figures cause by the time i start explaining drive train losses they will tune out and the discussion will be over.
+1. but your problem is having that conversation with the HSV boofhead in the first place :(
then you line them up and their bullshit about how they missed 2nd gear starts.
you fight fire with fire when it comes to n00bs. 'wow, your type r has an exhaust and makes 180kw at the engine... awesome!! now see that charade over there? 100 bux says you cant beat it."
Well if you don't care why did you click on the thread and make a sexually frustrated comment?
lol thats cute, you obviously missed the point. but thats all good.. n00bs are allowed to do that around here.
Easy, pull the engine out of the car and put in on an engine dyno, then put the engine back in and put the car on a dyno, then you will know what the difference is. IF you have a money tree that is. guestimation is the only way
saying that tho no 2 cars are the same UNLESS they are both factory spec, even then there will be differences as nothing is perfect.
The main reason people use % figures are so they can over-inflate their flywheel HP for bragging rights. Hell i've had one monkey try and tell me that all cars lose the same amount of power through the gearbox, manual/auto/skyline/commodore/300zx. When, for fun, i asked him how much he thinks my car is making at the flywheel he says "oh around 150" because he thinks all cars lose 20kw or some such bullshit.
Hmm lets see, 300ZX NA's make 120rwkw when freshly rebuilt with good compression, thats at 165kw atf. One that hasn't been rebuilt will normally see about 110rwkw which is about right for wear and tear which would bring it down to 155kw atf roughly. Mine makes 131.4rwkw so taking into account that 45kw loss i'd be making 176.4kw atf, which isn't correct as i also have an Underdrive crank pulley which reduces powerloss through all the accessories from memory it added 7rwkw on the dyno, so: 131.4+45-7=169.4kw atf which i think sounds correct.
there is a youtube video of a "1000 hp" r32 (looks like dyno @ croydon).
it was logging 500 and something awkw
the explanation given by someone connected with the car in the comments was
that they took 180hp off the 1000hp "for the back wheels" and another 100
"for the front wheels" and the result was ~730hp at the wheels, making the
car 1000hp at the crank, (and a 25% drive train loss).
So goes to show you can say anything about crank hp you want. Pick a nice
round number then work out the explanation!
Was the engine from that car ever dynoed by itself?
If not, then the 1000hp is just speculation.
180hp loss to the back wheels and 100 loss to the front is ridiculous.
Hahah Phil, but when i say im making 650-700 hp ......at the wheels.... thru an auto ...... they all just tend to say FAARRRKKKKKK....so all technical conversation bullshit stops and they all become riceboy fans :D
hahah
Gary
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
