  • Replies 66
Have you thought about recording the conversation with them? Not sure bout the legality of doing this but I reckon it might just make em listen as well. Just go back and say you wanna have a final shot at settling things, keep a recorder in your pocket (I know a lot of people that do this when gettin pulled ova by cops) and ofcourse keep calm and let him dig his own hole.
When thats all done, let him know that ACA may have a special interest in your recording. Meanwhile, I hope that MVIRA is able to help ya out.
Good Luck
Nah, I have to say... Dempo's car is my favourite falcon 'cause everything (so far) has been done properly and with a lot of time and consideration...
Only problem is if he keeps on going i'll HAVE to juice up the line to keep infront of him... :)
Not all bad when you think about it though... :)
Ok guys,
I need to have the car diagnosed and a quote to fix... where should I go? (mechanics)...
I live in Hornsby so it has to be close to home, has to operate on weekends too...
Also, while im at it... any good air-con places?... same as above...
cheers.
  • 4 weeks later...
Ok guys... thought i'd keep updating this (cause i said i would)...
Am having different tyres put on the car by the dealer because the ones on it don't match the placard... took a lil arguing but it's being done so no major dramas there...
I'll be sending in forms to DOFT and MVRIA soon so i'll be eagerly waiting a response and will keep you posted...
YEP!!! Damn snow tyres!!!!!!!! lol
they're getting swapped with different ones... How do i know you blitz/how do you know the car?
The dealer is in concord (not sure what area of sydney that is - not the best geographically)...
Yeah, i know eh man... I wasn't having a go at you either... just trying to say something without saying it if you know what i mean.... (:))
And yeah, I've found the guy who runs the place is EXTREMELY bodgy.... he's failed to meet his OWN WRITTEN CONTRACT on a number of instances so it's off the DOFT and MVRIA i go.... :(
Thanks heaps man,
Dave.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
