hey guys
i own r34 25gt and next week im going to inspection place for my rego. i currently use hsd coilovers on the fronts, and i need to replace it with the oem.
does anyone here can do backyard job at my place in Bruce? i got all the tools except car stands & coil compressor. if so, can u PM me?
and one more thing, i just moved my free-maintenance battery to the boot along with my sound system. is it gonna be a problem for the inspection? are they gonna be fussy w/ that?
cheers.
thanks for the offer, but i got the OEM as well. just need to pass the rego for 1 day and slap them back again.
i did the coilover bymyself, i cant put back the OEM because it needs spring compressor. ROFL.
I have a set of spring compressor's if you want to borrow them, But i wouldn't have to time to help you swap them over.
thanks for the offer guys. i really appreciate it.
i did try the supercheap's compressors but it was too big when i tried to fit it thru' the tie rod.
Edited by putraged
You shouldn't have to use the spring compressors until the whole shock/strut assembly is out. Also with coilovers you should never need them at all. What you will need them for is putting springs back onto your original struts.
Cheers,
Adrian
hey guys
cheers.
In relation to the second battery in the boot for your sound system. Providing it is secured properly and is in a breather box you shouldn't have an issue at the pits. Even the no/low maintenance battery's do need to be in the Marine box with breather. I've been down that road. No certificate required.
Cheers
S!N
Cheers,
Adrian
yea, i have no problem with installing coilover to my car but if u're putting OEM its gonna be a real deal.
OEM suspension's are longer than coilover's. hence u need to compress around 6-8 cm so it would fit.
hmm I cleared an unrelated defect with my coilovers in the car.
how can they pass it? since its illegal without engineer cert.
or u just got lucky the inspector didn't realize it?
Cheers
S!N
thanks for the info, sin.
i've secure it down with 4 point holders. i drove the car under extreme condition (drift esp.) and it still stay in the place.
what do u mean by a breather box? the whole battery needs to be covered in a box that have the access to fresh air?
where can i get the box from? can u show me the pic of ur boot?
cheers.
why dont you just raise them to a legal height and take it through? where are you going?
i'm going to my friends place in o'connor for inspection.
i don't think u can do that. basically it is still a coilover with adjustable height & softness, even though its on the legal height limit. i just asked my friend regarding to this matter.
its not easy for a coupe skyline to pass the inspection because some of them simply "pick" on us for being imports. i went to a mechanic shop in belconnen mall (forgot the name) and i asked a quote for swapping coilover with oem, they put $200 marks for the front shocks (labour only) until they realized its for r34 skyline (i went there w/ my friend's XR6T). for skyline they quote me $350. its not fair, because they think imports = must have lots of $$$ and they take advantage of that.
Lucky I guess, first time when I swapped over rego they didn't say anything about them, just told me the car was the lowest possible height allowed (they asked me if I had an engineers certificate, told them I bought it off the dealer I assume he may of had one)
2nd time was for a defect, they even told me that my rear coilovers were leaking. So not entirely sure coilovers are illegal, who knows, perhaps they just need to be locked into position.
Both of them I assume had enough knowledge about the car.
i just talk again with the inspection guy in o'connor. he said there's no other way to pass the inspection with coilovers installed except, u weld the height & damper adjuster. i guess they want the suspension to be fixed and not interchangeable.
oh gosh, since when rego-ing the car become more complicated. ACT doesnt have big long road like in WA or QLD anyway. why they bother it soo much.
My 34 passed an inspection at Dickson when I initially bought it with the coilovers installed. That was a few years back though. Shrug.
y u have to go to dickson? 1st hand imports?
man, those regulations becoming mooooreee ridiculous every year.
It didn't officially need one, I just asked the previous owner to get a cleared inspection report from Dickson to confirm I wouldn't have defect issues.
good for you, mate. i bought my car from a dealer in vic and rego-ing interstate car in act is just horrible, time consuming, and tricky!!
anyone can help me do this backyard? i'm gonna pay for it anyway, and some cold beer as well :rofl: . just because i wont spend that much money to fit it in any mechanic shops, they rip me off big time. ;)
    • Which are almost all nonsense. Ignore. Obviously enough, if it is not a porous block, then any such thing is a waste of time. External block surface? Would be a waste of time, if the block was actually porous. It would need to go on the inside, which is inaccessible, and even if the block was open deck so that that area was acessible, it would be unlikely to work. But seeing as this is all nonsense, stop worrying about it.   If the coolant is coming from the side of the block it is 10:1 odds that it is either a welch plug, or it is coming from the head gasket. Maybe from one of the coolant lines feeding the turbo, or even the heater. Liquids that leak from up high can travel sideways along casting surfaces or pipes, etc on the engine before finding a spot from which to drop.
    • Yeah rust is sadly also a bit of an issue on my car. Doubt there is many cars out there that actually have no rust in those aeas. The strut towers look fine but some of the surounding metal sheets show a bit of brown cancer peeking out from in between. I hope I can make do with external remedies and won't have to rip open the whole front end anytime soon. It looks somewhat minor compared to some shit I have seen online. I have worked on a few cars but I expect the RB26 to be my first 'engine out' job at some point.
    • Welcome Jan, It's very likely that you are in over your head. You'll just have to learn to swim hard and fast! These old rust buckets have more ways to bankrupt us than almost any other car. But hopefully there's nothing wrong that ruins the whole show! We can help a fair bit. There's plenty here who've been fixing these things for >25 years. cheers
    • Hi all. First off, thanks for reading my post. So end of last season I put the car away knowing I was leaking at least two fluids. One of them being rear turbo's oil. I went to my car recently that is waiting in a garage to take a peek with my boroscope to try and see if I can narrow down the souce of oil before taking it out of storage. What I found is not so great I think. The rear turbo is (probably) leaking from the oil drain. The hose and it's clamps are probably the original ones, so most likely just worn out or loose. However I spotted a line of rust going straight down from the turbo oil feed, as if water leaked out of there at some point. Also explains the red liquid that was dripping from my front subframe, which I initially thought was power steering. I can even see coolant drops hanging off the side of the oil pan as well. After a quick hit on the web I found a select few discussions about porous engine blocks. My question is if the pics of the turbo oil feed and the left hand side of the block (imgur link below) looks like it could be exactly that to you. Maybe someone in the community has seen it before and knows what it looks like. If it actually is a porously leaking block, has anyone attempted at fixing it with simple methods like putting a sealer in the cooling system and using something like jb weld on the block surface, or will it just leak in 2 weeks again? I could not find any detailed info or pictures on this topic. If I need a new engine, tell me softly. https://imgur.com/a/knVvmZ8
    • Hey all. I'm 23 and from Germany, September last year I bought a mildly modded 1995 GTR Vspec. Looks great and was fun so far, but I already have a list of issues of various severity that I need to take care of, potentially growing longer the closer I look. I just hope I'm not in over my head, I really want to keep the car and work towards it becoming great. I hope y'all will help me out in getting there, I am positive I will need help sooner rather than later to figure out how to proceed. greetings, some pics of the car I posted to imgur. https://imgur.com/a/StKkabz
