Hey guys.
Just wanting to get a few opinions on a few things.
I own a r33 Series 2 Gts-t Skyline.
i have no problem with over heating when on the move because getting good air circulation.
the problem is when iam just putting around town or in traffic..
Now it only seems to get xtreamly hot when putting around town with the ac on, the ac evaporator sits between the thermal fan and the radiator. On the highway the temp is fine and the ac works great.
With the ac off it works even better.. and getting around town with the windows down and no ac is just silly.
Would putting in a second thermal fan make much difference or do i just need a better coolent ?
https://www.sau.com.au/forums/topic/302777-overheating/
What have u checked, have u done any work on car recently
Would putting in a second thermal fan make much difference or do i just need a better coolent ? band aid
Does ur thermo fan even kick in, if so id try coolant flush
How long ago was the water pump done, impeller could rusted away
Edited by Dorifta
https://www.sau.com.au/forums/topic/302777-overheating/#findComment-5019716
I cant quite tell from your description, but do you have the factory clutch fan still on the car? Or an aftermarket electric one?
If you have an electric one, throw it away, and put the standard one back in place with the shroud.
Its really hard to make electric ones work properly, there are many threads around with issues regarding thermo setups. Most of them go back to stock because its not worth the hassle.
https://www.sau.com.au/forums/topic/302777-overheating/#findComment-5020103
i'd also check the thermostat. i've had similar issues in the past and found it to be the thermostat (but have also had another issue caused by a dodgy fan). the fact that it runs fine when going faster indicates 2 things to me, 1: the fan is dodgy, or 2: the thermostat is dodgy and restricting flow and the fan alone simply can't pump enough air to overcome the heat soak in the engine bay and also can't get enough air through the radiator to get all of the extra heat out of the radiator.
the best way to tell if the thermostat is the issue is by how long the car takes to warm up. with a working thermostat the car should be up to temp within about 5 mins of driving (not just sitting there letting it idle for 5 mins). if the car takes much longer than that, or the needle doesn't make it to the halfway mark, or sits lower than halfway when on the highway with the aircon off then the thermostat is the issue as it isn't opening when it should and isn't closing when it should.
https://www.sau.com.au/forums/topic/302777-overheating/#findComment-5020950
overheating at low speeds is usally caused by four things
Fans (bad clutch on mechanicals, lots with thermos. don't forget the shroud, its ugly but important
water pump loosing preasure
blocked radiator, you can try a flush in a bottle, they work soso, but a pro like natrad is better ( also bent fins on the core, they slow the air flow)
finally the old thermostat, they are usually cheep so just change em
if your motor has done a head gasket or similar in the past the water galleries in the block and such could also be a bit blocked, a flush take care of em
cheers
https://www.sau.com.au/forums/topic/302777-overheating/#findComment-5024257
another way to check thermostat is take it out and put it in boiling water and see if it opens
it doesn't always show the problem vey well though. i've done the boiling water test before and it seemed fine, but once i put in the new thermostat it solved the issue
If temp goes north sitting in traffic & at the lights, the fan clutch is suss; likewise, the temp goes down when you're on the move.
it depends on how low the temp goes. if the temp only goes to normal when driving faster then it's likely to be the fan. the 2 cars i've had with thermostat issues would get hot when sitting in traffic, but when on the highway would drop down to about 1/4 temp
https://www.sau.com.au/forums/topic/302777-overheating/#findComment-5024362
thanks guys might have to apply a few of these to my tow car which is starting to get hot very quickly when I'm not towing anything.
https://www.sau.com.au/forums/topic/302777-overheating/#findComment-5024482
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
