Its time to cleanout the shed as i sold my skyline, I have these parts for sale.
16" SSR Longchamp XR-4z Kai - 5x114.3 - $400
16 x 7 +48 Type C, with 205/55/r16 Maxxis MA-Z1 tyres 5000km old
16 x 8 +48 Type D, with 225/50/r16 Maxxis MA-V1 on wear indicators
Some gutter rash and marks, only 2 centre caps
KYB 'Super Special' shocks + Springs (bottom rubber mounts worn) Suit R32 gtst - Used $150
R32 gtst standard turbo, elbow and lines. Approx 140k km's - Used $190
x-force 3" cat (Type 1) - Used $115
R32 gtst standard intercooler (no pipes) - Used $40
R32 gtst standard fuel pump - Used $25
R32 gtst standard dump+front pipe - Used $35
R32 RB20 AFM + plug (1 broken mount but bolts on with bracket) - $50
Z32 AFM + plug (stuffed/faulty) Still works but maxed out at 185rwkw @ 16psi - Used $120
R32 gtst standard injectors X6 (a few cracked pintle caps) - $90
RB25 boost solenoid - Used $25
S14 SR20 boost solenoid - Used $25
R32 gtst standard Cam gears - Used $20
Super Pro Diff bushes - SPF2637K - New $50
R32 gtst factory option driving/fog lights - $90
K&N panel filter 33-2031-2 approx 30k km's old - $50
Jaycar IEBC (assembled but could never get it to work) - $35
Jaycar IEBC Hand controller and RS232 Connecting Lead (works perfectly) - $60
Performance Electronics For Cars magazine (to build jaycar kits) - $10
NICE NS453 wheel studs X10 (suit r32gtst front) - New $75
All prices are pickup from Ballarat, Vic. Postage at buyers expense.
https://www.sau.com.au/forums/topic/302778-shed-cleanout-vic/
Hey mate,
cant reply to ur PM as i need a minimum of 10 posts!
Im located in Epping, but i think i can drive to pick it up
Today(Tuesday) but give me a call/msg asap if thats fine..
Also is there anything wrong with the AFM apart from the mounts?
Would prefer pickup as i need this part asap!
Cheers,
btw my number again is 0401002944
what condition is the turbo?
shaft play? it is oil and water cooled right?
cheers
It has minimal shaft play, maybe 1-2mm. It's a standard r32 gtst turbo so yes, its water and oil cooled.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
