Hay all...
Just pissing around with my iPhone and I came across an App called Trapster... ...Did a search for it on the Forums and seems no one has talked about it...
Their web sight is Trapster... ...Seems to be very community driven...
Anyone on here using it???...
- - Laith...
https://www.sau.com.au/forums/topic/302787-trapstercom/
  • Replies 90
Been using it for a long time now :D
Great app, it pushes notifications of recent traps to you.
A bit draining on the battery though to have it on constantly while driving though so it's hard to report traps on the spot. I just wait til I get to my destination and then report it online.
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5019840
My old man uses it all the time cause he has an iphone now... It works good I guess if people report what they see. Anyways was driving on the south coast of NSW and my old man tells me there is a police car along a road we were driving, and yep sure enough there was a green VE Commodore police car sitting behind some bushes. Lucky I was doing the speed limit cause it was a verrrrry straight road and around double demerits...
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5020195
When I first got the app, I thought it'd be useless because no one would be reporting stuff.
Found out that there are a lot of people using it and quite a few people in my area are regular users because all of the traps have been reported by the same reliable sources :P
It's good to have a quick check of the "Recent Traps" list before you head out on a drive. It gave me a heads up once that I would be going through a booze bus, but I had no choice but to go that way haha.
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5020853
bloody hell, i almost banned your account thinking you were spamming.
way to post like a bot :P
Hahaha... ...I've been told a few times that I'm a MACHINE!!!... ...But that was in the bedroom and not the computer room... ...err... ...maybe once in the computer room... :bunny:
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5020902
Thanks for that mental image mate :P
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5020919
Hahaha... ...I've been told a few times that I'm a MACHINE!!!... ...But that was in the bedroom and not the computer room... ...err... ...maybe once in the computer room... :P
you make a lot of noise, blow hot air, break down constantly and leave a trail of oil?
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5021120
so is this an app that you just read before u go out? or do u keep it on while driving and it beeps when ur need a camera? pls explain?
You can do both. The web site is where all the work is done. The app on your phone is a portal to the web site. But it also streamlines reporting back to the site.
As you're driving it displays google maps (on iPhone at least) and will beep and point out where a cop is. If it's a green warning, it means it's just been reported and if you see a cop there too you give it a thumbs up, and it goes yellow. If it's yellow and you see a cop you give it a thumbs up and it goes red and means that at least three people have seen and reported that a cop is there.
If you don't see a cop there you give it a thumbs down and after a while if enough people do that then it will be removed.
It keeps the maps and app live.
I have my iPhone mounted in a TomTom cradle so it's clear to see and quick to report or thumb.
The app is free to download and use, apart from your phone data costs.
https://www.sau.com.au/forums/topic/302787-trapstercom/#findComment-5022927
  • 4 weeks later...
    • Definitely didn't put a N/A cluster in instead? The speed sensor (location) is different in both cars.... I think. This will obviously stuff things up.
    • Nah not the throwout bearing, it's something internal. I already replaced the throwout bearing. Mechanic misdiagnosed my car and thought it was a spigot bearing, went to another bloke who said it was an input shaft bearing. (I replaced everything when I pulled out the gearbox but didn't open up the gearbox.   In this video at timestamp 6:05 : Mine has the same sound  min
    • It is definitely to space it out and away for clearance during compression, and possibly for spring clearance to upper arm. That latter would only be true for springs that are same-ish diameter to stockers, and so that probably doesn't apply to Teins or most other coilovers.
    • Yeah, a mechanic who knows these cars told me even if I get a brand new gearbox the noise will return but will be less noticeable. I've heard someone also they this noise came back after 3,000km on a new or reconditioned gearbox. It is pretty f**king annoying though just hearing groaning most of the time lol. I wonder if an aftermarket input shaft bearing would fix the problem or how they are built.
    • All RB gearbags, especially the big turbo box, have rollover noise. Mine certainly does. Always has. Sometimes is worse than others - no particular idea why, although it is probably temperature related. I have smurf jizz in mine and have had to have it in there from the first day the box went into teh car. It simply would not select gears with the engine on, on day one, with normal oil in there. And so, the blue stuff has probably ruined almost everything synchro related in the box. But it has taken 12 or 13 years to get to the point where I simply must replace the box. It has become increasingly baulky of late, which might be symptomatic of the way I've been driving it, as much as anything. I shall have to make some corrections when teh new box goes in. Input shaft bearing noise will decrease with clutch pedal pressed because the drive is removed. But yes, more often than not noises that work like that are associated with the throwout. It won't matter either way, new box will mean this one can be relegated to the parts pile.
