Folks,
I'm looking at selling my wheels. They are WORK SC2s in "cut clear" (silver).
http://www.work-wheels.net/products/wheel_...&Item_id=70
Fitment fairly ideal for a V35:
Front 20x8.5 +11, tyres 245/30/20 tread still good maybe 50% left.
Rear 20x9.5 +18, tyres 275/30/20 tread down to the markers.
One of the fronts has a lot of gutter rash, which i will have professionally repaired before sale (hopefully within the next couple of weeks). Hence the EOI at this stage. There is also a little rash on one of the rears.
Price: $3,200. If you dont need me to have the wheel repaired I'm happy to talk price.
I will also consider trades + cash my way.
http://users.tpg.com.au/xscape23//P5270062.jpg
http://users.tpg.com.au/xscape23//works.JPG
http://users.tpg.com.au/xscape23//skyboat.jpg
http://users.tpg.com.au/xscape23//skyboatn.jpg
https://www.sau.com.au/forums/topic/302871-eoi-20-work-varianza-schwert-sc2/
The reason for sale is that I dont need 20" rims. Tyres are still expensive unless you are happy with nankangs (im not).
I'm going for a different look, something less VIP. I may just keep driving around on my factory 18s which are now painted black and wearing semis.
As for trades I will consider anything of value. If we are talking wheels then they must be 18" or 19" and with very agressive offsets.
Cheers.
*edit* - my guards are not lipped.
Sounds alright, im a bit old for the boi racer look and as my wife and I share the car, these wheels are right up my ally. What have you been quoted for a decent set of rubber? have you got photos of the damaged wheels?
p.s. dont have any rims for trade that would interest you.
Edited by not_a_zed
Do you have an idea on the repair cost?
How's the ride quality with the 20's? You had comments on earlier threads about wishing it were 19 rather than 20. What's your suspension set up at the moment?
Thanks.
I havent shopped for tyres in a while but expect $900ish for something cheap/nasty, or $1,500 for an alright set.
I will p.m. pictures of the 2 rashed wheels shortly. Cost to fix them im expecting a few hundred in total but havent got an official quote.
My suspension is nismo s-tune but with v35 RSR ti-2000 springs. Ride quality is too subjective. I will put it this way for you. If you are not comfortable in a lowered car then dont bother with 20s. These wheels on standard ride height make for a rediculous looking vehicle(IMO).
I made the statement about wishing they were smaller because none of the tyres i want are available in 20".
Thanks for the additional info and pics Brad. I was going to make you an offer on the rims as is but the damage is pretty bad (IMO). the cost of repair and new rubber on top of your asking price is just too much for me to consider paying for second hand rims. Thanks again and good luck with your sale.
No worries.
As i said, the damage would be professionally repaired before sale.
For anybody else who wants to see a pic of the damaged wheel, here you go:
http://users.tpg.com.au/xscape23//worksFR.JPG
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
    • No such thing as E30 in Sydney servos As stated above, flex fuel is your only viable,  and "safe" option I believe
