Well mate there is very little you can do. . . Once you have willingly transfered your money over to someones account it is legaly theres.
There is no point going to the bank because the person who own's the account hasnt broken any laws unless he was bound by a legal contract of some sort.
My mother works in a bank and she explained to me that this sort of thing happens alot and there is absolutely nothing that can be done.
The safest way to buy/sell goods interestate would definately be via C.O.D(Cash On Delivery). Even so, you may turn up to the post office and end up paying for an empty box.
Once again. . . It would be very hard to get your money back. . .
It's a quite risky business buying and selling via the internet.
It would cost you more to chase it through the courts than it's worth but a contract is a contract whether it's written, verbal, emailed or whatever. I haven't finished my law degree but I have passed contracts.
You could write him a letter saying that you know who he is and that you will sue him for the money plus costs and generally make life hard for him. You can use the Small Claims Tribunal or whatever it's called in your state.
Be up front with him and say that you realise that its going to be hard for you to get it back but that you are willing to go to the effort just to **** him over.
Was it through these forums? If so, maybe there is something that can be done????
This is absolutely incorrect. It's called online fraud and it has been targeted by police lately. Definitely file a police report - and be sure to e-mail him a copy.
yeh you can do something about it , online fraud. 5 years in prison .. for 130$ mwahahha. ey dude, are you sure he isnt replying on purpose or is it just he isnt home :D . but yeh , we would like to know who it is.
if i were you . id get a bunch of friends , drive to his house in "the tarago" and just drop him , walk in his house and tax everything and go home :D.
Can't you go to the bank and say that the dude messed you up? You paid for goods not received..
Failing that, call up the bank and say that you deposited the money into the account by accident (Wrong account no?). I've messed up the account number before and the bank has reversed my deposit.
While I don't advocate 'shady' tactics, if you have been wronged sometimes it's the only way out..
Um, i have been in a similar situation. You *can* get the bank to investigate and get the money withdrawn, but its around $40 I believe to get their investigations team (or something like that) onto it. For $130 it's hardly worth it.
Other option is what others are suggesting, speak to the cops and file a report. Again, because its a small amount cops aren't going to be jumping backwards to investigate it - but worth a try.
In my case it was an accident so I just asked nicely and they deposited it back.
If you are really pissed off you need to go down to the local police station and file a report there.
From there it should get escalated to the federal police but the guys are pretty busy these days.
If you just want to report this as an online crime, visit the AHTCC (Australian High Tech Computer Crime) website: www.ahtcc.gov.au website and grab the crime reporting form.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
