I would go for a high flow panel filter from K&N or Apexi. You can buy the K&N filter from Autobarn and the Apexi one most i think some traders on the forum sell.
In terms of the pod filter, again I would go for a K&N or Apexi. Depending on which state you're in, not sure if this would be a defect modification for you. Studies have shown the Apexi produces most power with the best filtration with the K&N coming in second best.
Cheers
Pod filters are a waste of time and don't gain any real performance over a high quality panel filter in stock airbox.
You just need to look at the Mines R34 GTR or any Mines car for that matter he uses panel in stock air box.
Go the k&N panel.... :rant:
4 an N/A +1 on keeping the stock airbox with a hi flo panel filter... really not worth it unless ur after hektic induction noise lol, u will need it fully encolsed, CAI, it fully mounted etc 2 much effort lol
I honestly don't hear any noise difference on an NA motor. Unless the hood is open and I'm sticking my head in to a get good look, I can't hear it.
On a turbo set up, it's pretty obvious.
on some NA cars it's very obvious though. i have had a pod on 3 6 cylinder cars (falcon, commodore and magna) and the falcon and magna it made a massive difference to the intake noise (sounded throaty) but the commodore it didn't do a thing.
A pod will suck hot air from the engine bay if you dont have a shroud for it and some form of cold air intake.
Go the quality panel filter
Hot air = fail
Yes should have explained self better, was thinking of a Pod inside a custom airbox
Go the k&N panel.... :D
Thanks
Thanks, was just asking as these things are so underpowered, not that I want it going to hard for my leaner daughter.
Just feels so slow compared to my 400rwkw+ BA Turbo.
Will just go with a K&N Panel Filter and look into improving the exhaust.
I went with the Apexi power intake and decided to make my own heatsheild, still not finished the sheild gotta make it look nice.
Cost me about $30 to make it, makes a big difference if its shielded or not
Thats what I was thinking, Thanks
i'd be worried if it didn't.....
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
