BsR33 Posted January 7, 2010 Share Posted January 7, 2010 Would like to know what Spark Plugs work the Best with the N/A R33 Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/ Share on other sites More sharing options...
SHANE666 Posted January 7, 2010 Share Posted January 7, 2010 probably the NGK Iridiums...i had the part number written down on my wall, but has gone missing! Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5022263 Share on other sites More sharing options...
mad082 Posted January 7, 2010 Share Posted January 7, 2010 now i don't mean to sound rude, but you should learn to use the search function. all the questions you have posted can be quite easily answered with a quick search. or you could've asked them all in the 1 thread. Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5022264 Share on other sites More sharing options...
OoskylineoO Posted January 10, 2010 Share Posted January 10, 2010 the most expensive ones rofl. Gains are nil to minimal. You wouldn't really notice the difference in spark plugs. Just some last longer then others. Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5025788 Share on other sites More sharing options...
UNR33L Posted June 2, 2010 Share Posted June 2, 2010 anyone know the part number that i need for RB25DE? just want some cheap ones as im selling car soon and in the morning it stutters at low revs on cold engine, once it warms up it gets a little better.. any info is great, thanks Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5269319 Share on other sites More sharing options...
SKiT_R31 Posted June 3, 2010 Share Posted June 3, 2010 (edited) The standard Nickel items are fine, NGK part number BCPR5ES-11 (or BKR5ES-11). The 5 is the heat range, 5 is most efficient on a stock engine, 6 is better for one that receives a regular thrashing and has mild mods (intake/exhaust). Power gain from different spark plugs is negligible. Platinum’s are less conductive than nickel (i.e. worse) iridium’s are slightly more conductive, but your unlikely to notice the gain, perhaps equally better off with V spark nickels or something, the most gain with spark plugs can be had by correctly indexing them, so they are all facing the intake ports (middle), you can do this by purchasing thin copper washers, to give you that half turn extra adjustment. some people have even managed it by buying a few packs of plugs and mixing and matching between holes (but copper would be best as it will squash as you tighten, so you can keep the correct tension). I run indexed BCPR7ES (gapped at 0.75mm with splitfires) on my RB25DE+T with water + meth spray. Edited June 3, 2010 by SKiT_R31 Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5271184 Share on other sites More sharing options...
RWG Posted June 3, 2010 Share Posted June 3, 2010 Hi guys, anyone know what plugs i should use in my V35 250GT, VQ25DD engine n/a, thanks Richard Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5273113 Share on other sites More sharing options...
SKiT_R31 Posted June 3, 2010 Share Posted June 3, 2010 Probably find the best info here; http://www.skylinesaustralia.com/forums/Sp...gs-t104405.html I've never worked with Nissan V6's, but I’d assume it would be the same story as the straight 6's. Pretty much run what the turbo boys run but a heat range higher. When you change your spark plugs, you can tell if you’re in the right heat range by the discolouration on the thread, if its past 3 thread lines, you probably want a colder plug (test after fitting your 5's) I used to have Indexed NGK BKR5EY-11's in my N/A RB25, had perfect burn and the plug wasn’t getting too hot. I generally think your best with standard nickels (what people call coppers, but they are nickel coated, and all plugs have a copper core) and would get the best performance & cost efficiency replacing them more often, than spending 6 x as much on an iridium and replacing it less often. This obviously changes if you have tom pay someone to change them for you, in which case it might be more efficient getting longer lasting plugs, as the labour would cost the difference. Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5273256 Share on other sites More sharing options...
Galois Posted June 4, 2010 Share Posted June 4, 2010 spark plugs have been heavily covered in the thread SKIT_R31 posted above. have a read through at least the last few pages, its good stuff Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5273542 Share on other sites More sharing options...
RWG Posted June 4, 2010 Share Posted June 4, 2010 Hi guys, Thanks for all the info i found the rec plugs for my car from that great thread on plugs, Cheers, Richard Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5275424 Share on other sites More sharing options...
TurboDoseBro Posted June 27, 2010 Share Posted June 27, 2010 Got NGK Platinums in my car right now. Don't know the degree of how spark plugs are gonna improve performance or feel but i can say they work normally. PFR5G-11. Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5315996 Share on other sites More sharing options...
Duchie Posted June 30, 2010 Share Posted June 30, 2010 I've got an R33 GTS and ive got iridiums in it they're NGK BKR5EIX-11 but your looking at around $120 for a set, if you're still looking for the right ones. Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5320482 Share on other sites More sharing options...
Son Gokou Posted July 1, 2010 Share Posted July 1, 2010 Hi guys,anyone know what plugs i should use in my V35 250GT, VQ25DD engine n/a, thanks Richard NGK LFR5AIX-11 Iridiums NGK list this plug as a direct replacement on the VQ25DD and VQ35DE. Link to comment https://www.sau.com.au/forums/topic/302952-best-spark-plugs-to-use-in-a-na-r33-gts25/#findComment-5323687 Share on other sites More sharing options...
