I am left in a delimma, I have an R32 GTR rear diff that is non-abs and I have a non-LSD auto S15 diff. Has anyone successfully swapped the internals of the R32 diff into an S15 diff housing. Reason I want to do this is that I want the ratio and LSD setup but I also need the ABS setup. Let me know as I would rather go this route than purchasing a series II RB25DET rear diff setup. Let me know as soon as please. Also, I am not removing the ABS and I need to hear it formt he horses mouth :P .
Jason.
Edited by TriniGT
https://www.sau.com.au/forums/topic/302958-r32-pumpkin-in-s15-diff/
Which ones? And how did they operate the 4wd system without a wheel speed sensor?
The N1s
After a couple of weeks, another light blinked on at the end of the tunnel. I recalled that the R32 GT-R N1 came from the factory without ABS fitted. Now the N1 came in two basic versions. The first was based on the standard GT-R, and the second as I understand it was based on the V-spec and V-spec II versions, which used the same Brembo calipers as the R33 GT-R (which I'm using).
Silbeer's NON-ABS BNR32 Master Cylinder Upgrade
I need to get a diff with the abs sensor to the front of the diff by the tailshaft. The R32 diff I have does not have it so I am wondering if I can swap the pumpkin into my S15 housing without problems to keep my abs setup.
If by 'pumpkin' you mean the diff centre, then it should be possible BUT I believe S15 auto used a viscous LSD (right ??) so you'd also need to use the R32 output shafts.
[caveat] I've never done what your trying to do, but I have done a few swaps of the S15 manual LSD (helical type, similar to R34 GTR) into 'other' R200's.
I have already removed the S15 hubs and fitted the skyline hubs to the S15 knuckles and attached the five hole axles in anticipation of getting the R33 Series II diff but if I can get the R32 guts to fit in the S15 housing using the halfshafts is the smallest of my problems. Gonna give it a go this weekend and follow with some pics.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
