hey people,
got another problem with this thing,
on wednesday the stag decided to lock itself in 4wd mode, its the worst thing to drive now, ive heard it happening with diffrent size wheels and so on, but we havnt changed a thing, its just happened,
were not driving it now untill hopefully one for you guys can find me a resolution,
just to let you know, the 4wd light stays on - on the dash, you can hear the attesa pump going mad and it surges big time under acceleration,
any ideas people,
https://www.sau.com.au/forums/topic/302969-4wd-issue/
do you know about the button on the dash? (left of steering wheel , looks like an I , well 4 wheels) that does exactly what you have described . it something goes wrong with the system it will just shut down and stay in 2wd
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5022469
Try taking the battery terminal off and then replacing it - hopefully that will reset the attessa computer. If not pull the 4wd fuse in the fusebox next to the battery. If that doesn't fix it (or at least make it driveable) you will have to pull the front drive shaft (4 bolts).
the attessa computer is hard to get at - its behind the trim behind the lh rear seat in the cargo area.
Somewhere there are fault codes - it has a little light that blinks.
Finally I have a spare attessa computer and also the unit that sits on top of the diff. (Also have a spare synchro switch if it is the switch in the dash that is stuffed).
Good luck
Bob
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5022540
the syncro swith doesnt work when the 4wd light is on, when you 1st start the car its good, the syncro swith works, but then the 4wd light comes on and you hear the attessa pump going mad and the syncro swith does nothing, but the 4wd light stays on,
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5022638
The light on the dash, is it the synco light or the yellow "4WD" light? At a guess it's the 4WD light and it's telling you there is something wrong with the 4WD system. First do as kiwi said, disconnect the battery, it may reset the error. I'd also pull both terminals off and clean the battery terminals and connections, these systems can go crazy with voltage issues.
If it still plays up after this you may need to get to the attessa ecu and read the error codes. An error code will point you in the right direction for a solution. Have a search in the tut/diy section, I think there is a write up on how to read the codes and what they mean. If it's anything like getting the codes from the hicas system you can do it from the drivers seat, it's just a sequence like, key on off 5 times, press brake twice, etc.... Then a light flashes the code on the dash.
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5023260
josh, its the 4WD light not the syncro light man,
it drives like ass when it does it too, and now its on all the time, so were not driving it till its fixed, but every time i have drove it it surges like crazy and doesnt want to stop, its like the 4wd just wants to keep moving, and its making all kinds of funny noises underneath too,
come on people
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5024065
You could help by saying what you have done (if anything). Did you try to reset the computers by cutting the power? Have you considered renewing the fluid or at least bleeding the system? (Assuming you have at least checked the level) Do some research in Google - there is stuff like this:
http://tyndago.googlepages.com/gt-rattesainfrormation
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5024185
bob, the only thing ive done mate was to cutting the power, i havnt had a chance to look at anything yet, been very busy at work and so on, but next ill check the attessa comp (doing that right now) to see what the codes are, then ill post up what i find,
the main point of this post was for you guys to give me some heads up for what to check,
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5024761
Regrettably i have only seen one guy who seemed to know all about the Attessa and he was on the SDU site and seems to have disappeared. It would be great if someone had the time to do all the research, get the appropriate bits of the manual translated etc because as time goes by more and more of us (and Skyline owners) are going to have problems and to most of us its a dark mystery! (And I bet most Nissan dealers wouldn't have a clue either!)
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5024833
mate, just counted the flashes on the attessa computer and i got a code 75, which is throttle position sensor, ive got a spare throttle body at work so im gonna go grab it, i rekon this would be why it idles really weird and its a cop to drive when the 4wd light is on, what do you guys rekon????
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5024850
Yep tps is wired to Attessa - good luck!
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5024934
josh im very lucky the fact that i got a whole motor sitting at work on an engine stand lol,
but after taking it for a drive 2nite for an hour i must say that my tps has not been doing what i should for a while, as now it drives perfect and idles perfect,
https://www.sau.com.au/forums/topic/302969-4wd-issue/#findComment-5025343
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
