  • Replies 48
I didnt get any :( but i knew i had to bed them in so i did 50 to 0 fairly fast about 10 times then went to 80-0 about 5 times and they were great and i could smell them the noise only started the next day :( but i just thought it might be the rotors as they were new.
it stops very well and i am pretty happy with them when i get the new rear rotors and pads i'll get the brakes bleed with new fluid and give them a hard time see if that makes then a bit quieter :/
When all else fails anti squeal paste is your friend.
Thats one of the biggest failures out there
I'd disagree. Maybe it's the kind that you used? Try using copper grease with shims. This absolutely deleted any noise from mine. I was running DS2500 front and rear at the time and it was so loud I thought it was going to break glass. Fitted the shims with copper grease. Dead quiet.
Running pagid rs14s now, still dead quiet.
pretty sure i mentioned this on p1 and no one noticed....
copper grease on the shims will kill ALOT if not all the noise
what sort of braking conditions are you guys referring to the squeaking with? my r32 has been doing this really bad since i've had it. it has slotted rotors and it squeaks only under very light braking, e.g when im rolling up to a red light and slowly coming to a stop thats where i get this horrible loud squeaking it drives me nuts. on two occasions i've had my rotors machined and it stopped the squeaking for about a week then back to normal. my old garage suggested it could be the pads but i've never gone to the trouble of replacing them when apart from the noise they work fine. the pads do seem to produce a lot of brake dust though. if i clean my rims then maybe after like another 2 days theyr filthy again with brake dust.. does that say anything with regards to the quality of the brake pads?
Edited by jonboy
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
