  • Replies 66
haha i wish it was that easy, i should have explained it better. whatever parts he has spare. which all seem to be upgrades on my current system.
having an ex drifter for a mate is a bonus.
doesnt help him having expensive taste in alcohol though haha
before you go upgrading your injectors or turbo you will need an aftermarket engine management system lol....so investing in a PFC or a haltec or what ever is a good idea....some people even get a RB20 ECU remapped to suit a RB25....or they get a VG30 ECU remapped to suit a RB25...speak to Jeff in regards to that as he is the man with the know how
yeah someone else has reccomended the vg30 ECU path, and i think my mate has one laying around or i may be mistaken. cheers for the help guys
not a bad idea but i would go with the Power FC if i were you mate....got on in the car and its damn brilliant....works a treat and most tuners love them
if you dont have a hand control for the pfc, then the cop would need to pull off the kick panel and know what a "Power FC" is.
Or you can put the standard computer cover on the PFC, then Regency probably wont even know. I know someone who has passed Regency with one :rant:
The PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk.
Thanx for the info damo is there anything you would reccomend to run on the auto as a replacement for a pfc or is it pretty much jus buy a manual car lmao??
Tis what I did! :rant:
If keeping the auto ... an Apexi SAFC and SITC can do the job nicely.
:rant:
Ruby how much did it cost you to get the manual put in and who did it??
The safc and sitc are they 2 diff things if so which would you reccomend?
I fitted the box myself with Luke's help. Took our time and ensured we did it right and it went in without a problem.
The SAFC (super air flow controller) allows you to control fuel ratios (to a limit) and the SITC (super ignition timing controller) allows you to make timing changes. If you can only get one, get the SAFC first as sorting out your fueling issues should come first. Tho the SITC is cheaper, but harder to come by.
Thank-a-you Damoo and Ruby will need to pm u n find out sum info about the manual conversion parts prices etc considering doing it :)
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
