  • Replies 66
haha i wish it was that easy, i should have explained it better. whatever parts he has spare. which all seem to be upgrades on my current system.
having an ex drifter for a mate is a bonus.
doesnt help him having expensive taste in alcohol though haha
before you go upgrading your injectors or turbo you will need an aftermarket engine management system lol....so investing in a PFC or a haltec or what ever is a good idea....some people even get a RB20 ECU remapped to suit a RB25....or they get a VG30 ECU remapped to suit a RB25...speak to Jeff in regards to that as he is the man with the know how
yeah someone else has reccomended the vg30 ECU path, and i think my mate has one laying around or i may be mistaken. cheers for the help guys
not a bad idea but i would go with the Power FC if i were you mate....got on in the car and its damn brilliant....works a treat and most tuners love them
if you dont have a hand control for the pfc, then the cop would need to pull off the kick panel and know what a "Power FC" is.
Or you can put the standard computer cover on the PFC, then Regency probably wont even know. I know someone who has passed Regency with one :rant:
The PowerFC only supports manual cars (excluding Toyota). It will work on an automatic car however it will not handle gear changes and simply keep the throttle nailed during a gear change. This will result in jerky gear changes and stress placed on the gearbox. The factory ECU during a gear change will communicate with the auto box and drop timing, ignition to ensure a smooth change. For those wishing to use PowerFC with auto you should consider a mechanical auto gearbox instead of an electronic. The PowerFC should work fine with a mechanical gearbox such as power glide, transbreak etc.
This is because the mainstream ECU's in Nissan etc rely on the main cars' ECU for gear logic change control and functions. Cars such as the Toyota have a seperate ECU for the gearbox change logic and control so it's not affected. Apexi chose not to port the Automatic gearbox logic code (as its very long and complex) into the PowerFC because I suspect they found its simply not worth it & too complicated. You can buy an Automatic PowerFC for a Toyota Chaser for example and it has auto logic control under SETTING, you can set the shiftmap, ramp up speeds etc as it has the code to interact with the Toyota AUTO ECU that is seperate to the main ecu. So in summary - Auto PowerFC's exist & work but only for Toyota. We have seen quiet a few Auto R33 Skylines with manual PowerFCs - some report they work fine etc and there is no difference - do so at your own risk.
Thanx for the info damo is there anything you would reccomend to run on the auto as a replacement for a pfc or is it pretty much jus buy a manual car lmao??
Tis what I did! :rant:
If keeping the auto ... an Apexi SAFC and SITC can do the job nicely.
:rant:
Ruby how much did it cost you to get the manual put in and who did it??
The safc and sitc are they 2 diff things if so which would you reccomend?
I fitted the box myself with Luke's help. Took our time and ensured we did it right and it went in without a problem.
The SAFC (super air flow controller) allows you to control fuel ratios (to a limit) and the SITC (super ignition timing controller) allows you to make timing changes. If you can only get one, get the SAFC first as sorting out your fueling issues should come first. Tho the SITC is cheaper, but harder to come by.
Thank-a-you Damoo and Ruby will need to pm u n find out sum info about the manual conversion parts prices etc considering doing it :)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
