All items located in Cairns, QLD. PLease contact me via e-mail (r32gtr@internode.on.net) as keeping up with pm's with the only 1 pm every 5 mins rule makes it very hard. I can also be contacted on 0437838032.
Item: Tomei Pon Cams
Condition: Brand new, in original packaging.
Price: $700
Item: Tomei Cam Gears
Price: $300
Item: Tomei Cam Cap Studs
Price: $300
Item: Tomei Valve Springs
Price: $500
Item: Tomei Sump Baffel
Condition: Brand new.
Price: $350
Item: Tomei Metal Gasket Kit
Price: $600
Item: Adjustable R32 GT-R Rear Camber Arms
Price: $250
Item: Mines Style cam cover baffles
Price: $150
Item: Blue alloy alternator pulley
Price: $40
Item: Oil Cooler Kit, Filter relocation
Condition: Used
Price: $200
Item: c's Short Shifter
Condition: Used
Price: $250
Item: Nismo Oil Cap
Price: $100
Item: Nismo Radiator Cap
Price: $100
Item: Greddy Turbo Timer
Condition: Used
Price: $50
Item: Standard Igniter
Condition: Used
Price: $50
Item: Nissan oil pump gasket
Price: $20
Item: Gates Timing belt
Price: $80
Item: Accel coils x 3
Price: $100
Item: Greddy Dual Gauge Pod
Price: $80
Item: ARP Head Stud Kit
Price: $500
Just to be clear. From now on anything purchased off me that is sent via post, i'm not responsible for what happens to it after i drop it off at the post office. Poastage will be the buyers risk otherwise i may as well just dump all the parts in the bin.
Cheers,
Rob
After much sweating the cam gears finally arrived this morning. That's 10 working days or twice the stated delivery time from Austrlia Post. Worth considering Express or Registered next time.
Packaging good and exactly as described.
Thanks.
  gtr fan said:
What brand is the oil cooler fittings and relocation kit Earls, speedflow etc?
Not 100% of the details of the kit as I did not buy it new. The pics show exactly what is included. Oil cooler is sold pending payment.
Cheers,
Rob
  UWISSH! said:
haha those radiator caps are $75 brand new from just jap
Right you are. Radiator Cap is now up for grabs @ $70. But the oil cap has increased to $140. Thank you for pointing out the value of these items as I was unsure.
Cheers,
Rob
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 馃憤
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
